Page 7 of 7 FirstFirst 1234567
Results 61 to 68 of 68
Thread: OEM GPS mod. Writeup + Pics
  1. #61
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Heres my crazy wiring setup
    Used two connectors off a 4 pin internal sound cable and then a connector off an internal usb cable
    Testing it out right now, weeee
  2. #62
    Feb 2005
    how are your guys reception? the max i got in open road is 10, never more than that. I guess my antenna big, expensive and crap.
  3. #63
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I installed one last week and I'm very impressed ....
    After bending a pin on my Earthmate cable it became very unreliable so I bit the bullet and bought the OEM 15L-W from MegaGPS.com plus this antenna from Ebay:
    http://cm.ebay.com/cm/ck/1065-29392-...tem=5810468863
    Total spent including shipping:
    OEM $88.72
    Antenna $24.98
    Total $113.70
    Installation went very well other than the minor hassle of xp detecting it as a serial mouse, but thanks to earlier posts I was able to fix that quickly. I used a serial header cable and an extra audio cable tha I had laying around to wire up the OEM. The soldering the wires was very easy. I used some double sided foam sticky tape to stick the OEM to the side of my unoccupied PCI slot on my Epia M10K. I have a truck so I routed the antenna through the third brake light-I've seen this done alot with XM/Sirius installs. Very easy installation all the way around. The GPS module performs so much better than my Earthmate. I'm getting a constant 9 satellite lock. With the Earthmate I don't remember getting more than 6. I would absolutely reccomend this for anyone looking for a GPS module for their install. I'll take some pictures when I have the camera out again.
    Rick
    '03 Sierra Denali
  4. #64
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Response.
    Thanks to all that have contributed information. I agree with Rick, this setup is recommended and again much more stable.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  5. #65
    i was searching around for some cheap oem gps modules, and i was wondering if anyone had any ideas on this Ebay gps module.
    http://cgi.ebay.com/3-OEM-NMEA-GPS-M...QQcmdZViewItem
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  6. #66
    hmm, but i wonder if that oem gps performance is similar to say the garmin unit for 85 bucks or whatever. im thinking you will need to make that little battery backup PCB thing, shown in someones picture above. hmm, whats peoples experience with the performance of various oem units?
    ive searched a few times, but most people are using dongles.
  7. #67
    Jun 2004
    NH
    Garmin 15L & H models seem to be the most reliable / accurate (depending on the antenna placement)
    F
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  8. #68
    currently i have my usb mouse under the dash of my car attached to an air vent. it probably averages about 5-7 sats the most was 9 and only if im in the city with tall buildings itll drop to 2 sats or less. if i were to put the antenna in this same location, would it do any better? or should i find a different spot? say in the windshield cowel where the wipers go.
  1. Stealth OEM install in MR2 Spyder - Magazine coverage!
    By silencery in forum Show off your project
    Last Post: 07-31-2008, 04:15 PM
  2. Sony XA-300 mod pics?
    By tom2112 in forum General Hardware Discussion
    Last Post: 10-27-2004, 03:48 AM
  3. Replies: 9
    Last Post: 10-25-2004, 01:34 AM
  4. Some mod pics of Remote and D Link radio
    By gospeed.racer in forum General Hardware Discussion
    Last Post: 01-14-2004, 03:10 PM
  5. pics of my pioneer slot DVD window mod =)
    By moahdib in forum General Hardware Discussion
    Last Post: 04-30-2002, 05:10 PM
