Results 1 to 8 of 8
Thread: delay off circuit? (not for psu)
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Hey everyone,
    I am going to be installing a rearview cam that will go on automatically when i put the car in reverse but i want to also be able to touch a momentary (qtouch) switch and have the cam turn on for 20-30 seconds. Does anyone know how to do this? I want this switch to be independent of the computer so this will have to be a hardware based solution.
    Thanks,
    `S
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You should be able to do that with a simple 555 timer circuit. A microcontroller is another option.
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by rando
    Thats what i'm looking into right now, but trying to find what i need is a llittle confusing. I'm pretty new to building with ic's but i'm not that bad at it. Do you know of any sites that have a good schematic and write up?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    i think i found it...20 seconds but it uses a 4013 flip/flop ic... still looking for a simpler 555 ic schematic
    http://www.discovercircuits.com/PDF-...ffwtimeout.pdf
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    That looks pretty straightforward, I doubt you're going to find much simpler than that.
    Constant Bitrate cbergeron's Avatar
    Yep, Rando's right. You should use a 555. Look up "monostable one-shot multivibrator" on google and you should get some simple circuits like that. About 8 years ago I built a simple circuit to put my power windows down using a single touch button. It was an old Camaro with power windows, but they were slow and I hated having to hold both buttons down while they slowly came down (I lived in Florida and the car had Glass T-Tops). Anyway, long story short, using a 555, and a Capacitor/Resistor combo (for timing) you can create a simple circuit to do this.
    Kind regards,
    CB
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
    Ok, here's what I found via google:
    http://www.uoguelph.ca/~antoon/circ/monovib.htm
    You change the delay time by multiplying R1 and C1.
    Kind regards,
    CB
    Edit:
    You'd probably be wise to clean up the input supply at 5-15v by putting the vehicle power through a 7805.
    Also, you'd have to add a simple transistor inline between the pin 3 output and the relay, because the 555 can't source enough current to power a decent relay.
    Finally, you _might_ need to debounce the switch to prevent false triggers. I experienced that only one time though, using the circuit I described (it was a long time ago ~1997). If you power the circuit from an ACCessory line (I would assume), the worst case scenario would be a 20 (or whatever) second rear-view camera view.
    Have fun!
    -CB
  1. Accessory Line Delay circuit - Any ideas?
    By MiniRX7 in forum Power Supplies
    Last Post: 01-27-2004, 09:00 AM
  2. help with delay circuit
    By albysure in forum Off Topic
    Last Post: 05-30-2002, 08:53 AM
  3. delay circuit
    By jshrieve in forum Power Supplies
    Last Post: 04-18-2002, 10:38 AM
  4. Anyone haveing probs with the relay delay circuit
    By Synx in forum Power Supplies
    Last Post: 10-01-2001, 04:15 PM
  5. The power-off delay circuit
    By ppgt94 in forum Power Supplies
    Last Post: 08-10-2001, 10:13 PM
