Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Need a circuit board
    Dec 2004
    VA
    Ok, really new to this idea so help me out here. I need a board like what is behind these LEDs:
    Where can I find the such (any paticular (physical) stores?). And I know this is probably a really basic question, but how once I put some leds into holes in the board with the solder deally, how do I make an electrical connection to the next LED?
    Search came up with nothing, and couldn't find specifics from google. Alls i need is the simplest of simple.
    merci beaucoup
    Car Mods
    -no car mods
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    look for some strip-board. it has rows of copper with holes in and you just cut the copper with a drill to break a run and branch from run to run with wire. its used to make prototypes and on-offs if you cant be bothered to etch a circuit. Or get some copper clad and etch your own boards.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    For something like the LEDs above, it's probably easier to just drill holes in a sheet of plastic and run wires around rather than making your own circuit board.
    Quote Originally Posted by eag182
    That's sort of the point of a circuit board - it has traces on the board connecting the various components together.
    Dec 2004
    VA
    I understand, but theses leds would be pretty close.
    Car Mods
    -no car mods
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    It may help if you state the purpose of the project.
    Dec 2004
    VA
    It really won't. The connections now what I need to know, sans wiring. And just where I should get this stuff, preferably in english!
    Car Mods
    -no car mods
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Depending on the voltage/amperage input of the power supply, the amount of LED's you plan on using, the voltage/amerage of the LED's, and if you plan on wiring in parallel or series, the way you would need to wire this would change. So, instead of insulting Llama, why don't you answer his question? Obviously you don't know much a bout electricity, so who are you to judge weather your purpose affects how it needs to be done?
    Quick! To the Popemobile!
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Yeah, I agree with Biohazrd. We really have to know the application to give good advice man.
    Tidder
    Try RevFE
    Jul 2004
    All over the world
    I don't even know what that board is or what it is supposed to do. Are they supposed to just light up? Are they indicators? Do they need to be interfaced? Does it just scroll back and forth like in knightrider?
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    if it were me. Id just use WOOD.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
  1. Lilliput USB Circuit Board...
    By gleinz in forum LCD/Display
    Last Post: 01-18-2005, 05:09 PM
  2. Building proper circuit board.
    By Arathranar in forum Power Supplies
    Last Post: 11-15-2004, 12:59 AM
  3. Need Someone to draw circuit board (Simple)
    By frodobaggins in forum General Hardware Discussion
    Last Post: 09-20-2004, 05:57 AM
  4. WTB Lilliput circuit board or FS Lilliput Screen
    By hifiguy in forum Classified Archive
    Last Post: 07-13-2004, 12:32 AM
  5. Frying Circuit Board
    By Joe689 in forum General Hardware Discussion
    Last Post: 06-07-2004, 07:05 AM
