the 400 watts is probably for the AC side ... so that'd be 120v @ 3.33 amps as you said ... but remember there's no such thing as free power ... extra current is needed on the DC side to get the higher voltage on the AC side. In order to get your 120v @ 3.33 amps on the AC side, you'd need 33.3 amps @ 12v on the DC side. And that's assuming the inverter is 100% efficient (which it's not!)
anyway, in reality you probably won't be pulling more than an amp or two on the AC side.
LinkBack URL
About LinkBacks
