Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Connecting 2 circuits to one relay?
  1. #21
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Blah! OK, you made me realize my mistake in vocabulary. triggers != sources. Ha.
    I wanted two sources to connect to one relay to activate the relay. I know the relay coil's rating, but not offhand. I guess all I need to do is go out there, run the ACC line and hook it up.. Thanks.
  2. #22
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    right ... in relay terms I see a trigger as the signal that activates the coil ... and the source as the larger power source that the coil allows to flow.
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
  3. #23
    Mar 2005
    Erp, then I had it right. :-P
    Let me describe the problem. I have a relay I need to trigger when either A) ACC line is on or B) 12V from computer is on.
    How do I connect?
    Solution:
    DIODES!
    ___ / ------|<------- ACC
    \-------|<------ 12v+
  4. #24
    Oct 2003
    Atlanta GA
    yes ... we're saying the same thing ... you could use the diode option you have there, and feed the output of the diode to a SPST (Single Pole, Single Throw).
    You could also use a SPDT (Single Pole Dual Throw) without the diodes. SPDT has two coils (you'd connect ACC to one, +12v to the other) and has one source. So activating either coil will activate the relay.
    And again, you could achieve the same effect by using a DPDT (Dual Pole, Dual Throw). Again, two coils, but this time two sources. So by tieing the proper pins together you can turn that DPDT into a SPDT and use the solution above (with more possible current).
    What have we learned? You've got options :-)
    My JeepPC Install
  5. #25
    Mar 2005
    Well - to be honest I've never heard of a relay having two coils. Mine are usually spring loaded. NC and NO positions. I'm sitting here with a soldering iron and a relay, with some solder, and these here diodes. Getting ready to do the original schematic I saw. One alst question - the end of the didoes w/ the white bar --- goto the positive or Vcc? Towards the ACCA nd the 12V right? Just ran the ACC wire. Thanks.
  6. #26
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by shakes
    Eh?? An SPDT gives you two contact paths (as opposed to a SPST that switches between a contact and no-contact. It doesn't apply to relays, but switches can also have SPxT, where x is the number of positions.) In either case, a relay only has one coil.
    I can't do good ASCII art, and I don't want to explicitly poach another sites graphics, so I give you Google Images :
    SPST
    SPDT
    DPST
    The green on black images illustrate it quite nicely.
  7. #27
    Mar 2005
    Mushin: I understand that. Here's a quote from a previous post: "SPDT has two coils "
    Anyways - I just realized I needed to go with relays. My dumb.
    *builds circuit*
    *plugs it in*
    *tests it*
    *unplugs circuit goes to old way*
    I guess I'll just get the relays tomomrow from mechanice friend before work. Thanks for the help though
  8. #28
    Oct 2003
    Atlanta GA
    Quote Originally Posted by mushin
    hmmmm ... yes yes, you're right.
    guess I myself was getting confused between Poles and Throws.
    My JeepPC Install
  9. #29
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by KyleYankan
    Don't you want a DPST relay ?
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 07:55 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  4. Queston conerning stinger 200 amp relay
    By vash in forum General Hardware Discussion
    Last Post: 05-25-2004, 10:15 AM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 04:50 AM
