Results 1 to 6 of 6
Thread: help please, problems with a PIC circuit
    Dec 2004
    ive got a digital encoder for some funky controls in the front, and im rigging it up to the controller board on a keyboard for ease of use etc, but this thing aint keen on running thru a pic, when i use a test board this works fine (with push switches and LEDs) but as soon as it goes on the main board it wont output anything.... (btw the test board isnt my design, a velleman k8048)
    so anyways, heres my shchematic, the little block at the top is the encoder (a little twizzly knob incase your wondering hehe)
    Registered User
    May 2003
    The MCLR need a 10K pull up resistor to the +5V.
    If you check the velleman 8048 you find that theres a pull up resistor on the MCLR already, reason why it work on the test board and not off it.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Also a bypass cap between VDD and VSS is a good idea. 100nF should be fine.
    Registered User
    May 2003
    ...and installed very close to the PIC
    Mar 2004
    Redondo Beach, CA
    ...righto!
    Dec 2004
    thanks... mucho appreciated
  1. opus problems
    By studmonk3y in forum Power Supplies
    Last Post: 03-29-2005, 04:09 PM
  2. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
  3. Frying Circuit Board
    By Joe689 in forum General Hardware Discussion
    Last Post: 06-07-2004, 06:05 AM
  4. Timer circuit? Shutdown?
    By dudah85 in forum General Hardware Discussion
    Last Post: 07-09-2001, 07:22 PM
  5. Can someone write me a PIC program 4 a awesome s/down controller please?
    By gizmos in forum General Hardware Discussion
    Last Post: 07-17-2000, 12:43 PM
