Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 67
Thread: Kenwood Cd-Changer To AUX. Input
  1. #11
    Dec 2005
    Would I be able to use a 100k resistor?? or a couple of 1.5k resistors instead of a 10k resistor, I've been on holidays and havent been able to get out.
    Cheers
    MaT
  2. #12
    Dec 2005
    you can use 2 100k resistors in parallel or 7 1.5k resistors in parallel. I don't know if other values are acceptables. you can try some values you have.
    Cheers...
    simons
  3. #13
    Dec 2005
    in parralel you mean
    This is my lil diagram to understand what you mean
    key:
    resistor = ---[||||]---
    Diagram:
    Parallel is that? or is that series, i always get the 2 confused.
    Cheers
    Mat
    P.S- I just found 10x1k resistors, i might just use dthem in series since im soldering it to the mainboard anyway, no one will see and i can do it neatly Thanks for all your help.
  4. #14
    Jan 2006
    hi there
    i have tried this with my KDC-MP7018 and it works great
    then i tired with my mates HU which is a little newer and got nothing so obviously the pin outs are diffrent to the ones above. has anybody got a diffrent set of pinouts. or has got it to work but not using the above pinouts?
    thanks in advance
  5. #15
    Dec 2005
    Quote Originally Posted by BenGDoG3851
    hi there
    thanks in advance
    I have 2 other pinouts from a KRC. but none of them worked for me.
    try this:
    and this:
    CYA
    Simons
  6. #16
    Jan 2006
    so short pins 1 and 12 with the 100k?
    will try within the next few days an let you ppl no whats happened.
    thanks
  7. #17
    Dec 2005
    thanks
    on both pinouts I have posted before, the resistor isn't needed... But if it doesn't work.. try to insert the 10k resistor.
    The resistor is needed if U want to build this adaptor:
    http://nodivisions.com/tech/kenwood_aux_adapter/
    NOTE: the resistor is 10K not 100k
    Simons
  8. #18
    Jan 2006
    on the second day of using this mod on my KDC-MP7018 it didnt work. i checked the resistor and yes i had used a 100k not a 10k. poped a 10k in there and its been sweet since. so i'd say thats what the problem was with my mates. strange that the 100k worked for a bit in mine then died. but there is no point in trying to do this mod to my mates car as he is selling it now.
    but thanks for the help
  9. #19
    Dec 2005
    But the resistor must be 10K N O T 100K !!!
    Try with a 10K resistor... I don't know why the resistor worked for a bit and then died..
    CYA
    simons
  10. #20
    Jan 2006
  1. Delco units with CD changer input
    By Chairboy in forum Car Audio
    Last Post: 09-07-2008, 12:28 AM
  2. FS/FT: Kenwood 10 Disc CD Changer
    By BiohazrD in forum Classified Archive
    Last Post: 10-22-2004, 12:40 PM
  3. FS: Kenwood CA-C1AUX - Aux Input Adapter
    By hd54321 in forum Classified Archive
    Last Post: 10-07-2004, 10:11 PM
  4. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
  5. cd changer interface
    By SKIDrow in forum General MP3Car Discussion
    Last Post: 05-10-2001, 10:02 AM
