Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 67
Thread: Kenwood Cd-Changer To AUX. Input
  1. #21
    Jan 2006
    does it matter if you use 10k resistors @ 1/2 watt or 1/4 watt? radioshack gave me both
  2. #22
    Dec 2005
    Quote Originally Posted by SlimMJS
    I think the current flowing through it is few milliamperes so a 1/4 watt resistor is suitable
  3. #23
    Jan 2006
    I'm having problems...
    I have a Kenwood KDC 4007 and am trying to get an AUX input working. The CA-C1AX doesn't work for me as it is an older model ('95-'98 or so).
    I have the 10k (1/4watt) bridging the 1 and 9 pins as indicated in this pinout:
    The result is a "NO CH" or "CH NO" message when I try to select the CH changer source.
    I thought this was what it would be displaying so I moved on to the audio wires.
    Using the shielding wire on the outside as the ground and the center wire as the signal, I soldered them for a stiff insertion and plugged them into 6 & 12 and then 6 & 8 with a signal coming through the wire, ready to be heard and the unit was on and turned up, but nothing was heard.
    Am I doing something wrong? Using the wrong pinout? I saw these too:
    Any help would be appreciate. Thanks.
  4. #24
    Jan 2006
    as far as i can tell ur doing it right.
    i used a 1W resistor but i rekon 1/4w is fine.
    it might be that the pinouts you used are not for your HU. try the other two.
  5. #25
    Jan 2006
    Quote Originally Posted by BenGDoG3851
    I tried the other 2 pinouts for the audio cables while leaving the resistor in the same 1 & 9 pins from the first pinout (giving me the CH NO message) as well as plugging the audio cables all over the place, but still no audio
    Is the CH NO message what I am supposed to be seeing or is that wrong also? I thought that the audio cables are my only problem. It's likely something stupid that I quickly overlooked, grrrr
    edit:
    I tried the other two pinouts and couldn't even get the CH NO message when I moved the resistor, so it MUST be the 1st pinout. I now assume that I the CH NO message is what I want to see to know that it is taking input from the "CD changer/AUX" input. But what am I doing wrong with the audio cables?
  6. #26
    Jan 2006
    ok well on mine i cant even get acces to the changer menue unless i have the resistor in there.
    so without resistor:
    all off > tuner > cd > all off > tuner > cd > etc etc
    but with resistor i get:
    all off > tuner > cd > disc aux > all off > tuner > cd > disc aux > etc etc
    do you get something similar?
    double check you have the correct pins and that nothing is shorting out. (dont forget to check the plug at the other end of the cable) check you actually have a 10k (as u may of read the 100k worked for me but not for very long so double check you have a 10k)
    and finally do you have an actual cd changer u could test the HU with? or a mates one or something.
    edit: mine says the word "disc" then "aux" it stays on the word "aux" never seen it display "CH NO" but this could just be that we have very diffrent HUs
  7. #27
    Jan 2006
    Yes, mine is working similar with, then without the resistor, so I assume that part is correct. I dont get the word AUX, but rather just the CH NO when it is not playing Tuner or CD, so CH NO is the 3rd position. With the Head Unit in CH NO mode, I can't get audio to come through, no matter where I plug the audio cables, so it seems. I have no cd-changer to see if that works, sorry. I really appreciate your help. If you can, my IM's are AIM: matthewslimmer MSN: matthewslmmer@hotmail.com and Y!: matthewslimmer. Thanks!
    edit:
    does this make any sense to you? http://www.lompec.nl/KenwoodPC.htm
  8. #28
    Jan 2006
    hmmm would need more info on the so called "78L05"
    note: i added you to msn
  9. #29
    Jan 2006
    it wont add you to msn properly cause it says u dont have a passport.
  10. #30
    Jan 2006
    typo... matthewslimmer@hotmail.com
    sorry
  1. Delco units with CD changer input
    By Chairboy in forum Car Audio
    Last Post: 09-06-2008, 11:28 PM
  2. FS/FT: Kenwood 10 Disc CD Changer
    By BiohazrD in forum Classified Archive
    Last Post: 10-22-2004, 11:40 AM
  3. FS: Kenwood CA-C1AUX - Aux Input Adapter
    By hd54321 in forum Classified Archive
    Last Post: 10-07-2004, 09:11 PM
  4. Replies: 4
    Last Post: 02-16-2004, 09:08 AM
  5. cd changer interface
    By SKIDrow in forum General MP3Car Discussion
    Last Post: 05-10-2001, 09:02 AM
