Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 67
Thread: Kenwood Cd-Changer To AUX. Input
  1. #31
    Jan 2006
    I have two older (pre 2000) kenwood HUs for which the CA-C1AUX also does not work. I tried all kinds of different combinations with the resistor but only got NO CH. I think the older models actually need a clock signal and/or communication from the cd changer to work .
    So, I finally ended up hacking up an old temperemental changer, took out the electronic 4"x5" circuit board (brains) of the unit and threw the rest of the changer away. When I plug it into the HU, the receveiver thinks it has a faulty changer and displays E99. However, the audio channels are open so using the pinouts in this thread I was able to "tap" into the cable and connect my iPod that way. "E99" now simply means I'm in AUX mode!
    It works great! I put the circuit board in a small box and simply stuffed it and the CD changer cable behind the dash. I then guided my RCA/mini jack cable to the front where the iPod plugs in.
    I should have taken a pic before I install it. If I ever upgrade I'm sure I can sell this custom cable!
  2. #32
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Quote Originally Posted by DarquePervert
    I like the way the host of your images protects them.
    DON'T HOTLINK, JERK.
    Its not hard to see who is the jerk between you and me..
  3. #33
    Jan 2006
    Quote Originally Posted by SlimMJS
    Yes, mine is working similar with, then without the resistor, so I assume that part is correct. I dont get the word AUX, but rather just the CH NO when it is not playing Tuner or CD, so CH NO is the 3rd position. With the Head Unit in CH NO mode, I can't get audio to come through, no matter where I plug the audio cables, so it seems. I have no cd-changer to see if that works, sorry. I really appreciate your help. If you can, my IM's are AIM: matthewslimmer MSN: [email protected] and Y!: matthewslimmer. Thanks!
    Can anyone else lend a hand here? I'm still having problems. Thanks!
  4. #34
    Dec 1969
    I did this a long time ago , so I cant remember exactly what it says on the LCD , but when I pressed on Source (the button to change between fm 1 ,2 ,3 AM) and the resistor was in , I could scroll to DISK - --- --(would look something like that).
    Then from there, I plugged a sound input , and I can control volume and bass/treble.
  5. #35
    Jan 2006
    Quote Originally Posted by kevinlekiller
    I think that mine will be displaying the "CH NO" message when taking that aux input from the faked changer, but my biggest problem is in the audio cables, where to plug them. The pinouts I saw in earlier posts arent quite working for me. Please see my posts from the last couple days and you'll understand more.
    Again, I really appreciate all the help you guys have given me!
  6. #36
    Dec 1969
    Maybe the head unit requires a clock signal to let the sound pass or something.
    http://www.lompec.nl/KECANI.htm
  7. #37
    Jan 2006
    so, basically, I'm out of luck
  8. #38
    Jan 2006
    i dont think its your audio cables. i think "ch no" might mean no changer or something. u sure u've got the right size resistor?
    kevinlekiller how did you or your source come to the conclusion that 10k was best? was this measured sumhow? if so maybe the problem with SlimMJS is that the resistor is not tricking the HU into fully thinking its a changer. like it can see something but not a proper changer.
  9. #39
    Dec 1969
    Quote Originally Posted by BenGDoG3851
    The guy bought a comercial aux adapter and reversed engineered it , and noticed it was only a resistor.
  10. #40
    Dec 2005
    edit:
    does this make any sense to you? http://www.lompec.nl/KenwoodPC.htm
    I can't figure out what HU is this link http://www.lompec.nl/KenwoodPC.htm talking about
    I noticed that both pinouts i gave you have differents pinouts from that in the schematic.
    You can add me to msn if u want more information but I don't know how i can be helpfully to you...
    simons131[AT]hotmail.com
    CYA
    simons
  1. Delco units with CD changer input
    By Chairboy in forum Car Audio
    Last Post: 09-07-2008, 12:28 AM
  2. FS/FT: Kenwood 10 Disc CD Changer
    By BiohazrD in forum Classified Archive
    Last Post: 10-22-2004, 12:40 PM
  3. FS: Kenwood CA-C1AUX - Aux Input Adapter
    By hd54321 in forum Classified Archive
    Last Post: 10-07-2004, 10:11 PM
  4. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
  5. cd changer interface
    By SKIDrow in forum General MP3Car Discussion
    Last Post: 05-10-2001, 10:02 AM
