Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 67
Thread: Kenwood Cd-Changer To AUX. Input
  1. #51
    Feb 2006
    yeah i see that.how can i do that?generate the correct clock signal independently....????
  2. #52
    May 2006
    Exclamation AUX CONNECTION with bad sound
    Hallo everybody,
    I'm an owner of the KDC-PSW9524 and I made also my CA-C1AX by myself,costs only 1x 10K resistor 5 cent instead of 20 euro for a stupid cabel , and I get the AUX in my LCD with sound (very great )
    BUT :-( one problem, the sound itself, No noise but it sounds like an 8bitrate sound , really strange, the CD and Tuner of the HU gives excelent sound, and my Ipod itself gives excelent sound with a headphone connection! so it's not the Ipod. the problem has to do with aux connetion I made.
    -I can't figure out, why the HU gives this bad sound quality through the AUX
    -Could this be a short in the circuit I made between the Audioground(-) and
    Audio L(+) or Audio R(+) ??? or is it an internal failure in the HU itself????
    Can anybody tell me what I did wrong?????
    Thanks for reading my reply [/QUOTE]
  3. #53
    Dec 2005
    Quote Originally Posted by musicpower
    Hallo everybody,
    I think that it could be a short circuit. Check the connections in the aux plug and in the 3.5" jack.
  4. #54
    May 2006
    New Zealand
    Fake Changer
    I tried all those resistor links but got as far as NO CHANGER , so I got a bit frustrated and gave up until I purchased faulty second hand CD-changer with 13-pin cable. I tried to repair the unit but it looked like it needs some parts and it may be expensive to repair even I do the job myself. I used to repair consumer electronics. Then I came up with same idea as fastedie. I just removed the main circuit board and connected that to the headunit. Yes, it said E99 error message meaning something is wrong with the changer.
    I just tapped the pins with wet finger and could hear noise from the speakers, good.
    Then I connected a 3.5mm jack into the points and had to replace 2 electrolytic caps so I could fit the jack directly into the metal frame where bigger transistors are connected to, More testing using my HP Ipaq 2210 as MP3 player. Good sounds. Then I went for a longer drive and had to plug in car charger for the Ipaq. This caused noise, bugger. I added 10uF elcaps in series with the input and this helped quite bit. Maybe shorter cable would be the answer or improving the filtering on the charger?
  5. #55
    May 2006
    Aux Issue
    Quote Originally Posted by simonspt
    Thank you Simonspt, you're totally right, I found the shortcut en the problem is solved,,, Nou I enjoy driving with my HTC-Universal, it's my Mp3/Video player, my navigator and my GSM smartphone. Excellent sound thanks to Kenwood
  6. #56
    Una
    Una is offline
    May 2006
    Hi!
    Here are two great links witch i used when i made my own AUX adapter.
    All i needed was a RCA cable and some wire. Didn´t use any resistor.
    Remeber that moast of the pictures show the 13 pin-din conector (Male)
    http://www.xmfan.com/viewtopic.php?t=16631
    http://nodivisions.com/tech/kenwood_aux_adapter/
  7. #57
    Dec 2005
    in the first link there isn't any image...
    and in the second link the resistor is present, as it has been linked in the first post of this thread!
  8. #58
    Una
    Una is offline
    May 2006
    No Need for the resistor!
    Yes i can see that he saysu need aresistor, but it works just aswell just to connect these with a piece of wire...at least itworks for me=)
  9. #59
    Jun 2006
    hello,
    i have a kdc-6024g and this pinout is not valid for my model:
    but this pinout IS VALID!!!! :
    http://img12.imageshack.us/img12/141...kenwood1kb.gif
    YOU can use the same 10k resistantce between 2 and 12 pins
    Regards
  10. #60
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Yea, some models have different pinouts , depending on the year it was mfc also.
  1. Delco units with CD changer input
    By Chairboy in forum Car Audio
    Last Post: 09-07-2008, 12:28 AM
  2. FS/FT: Kenwood 10 Disc CD Changer
    By BiohazrD in forum Classified Archive
    Last Post: 10-22-2004, 12:40 PM
  3. FS: Kenwood CA-C1AUX - Aux Input Adapter
    By hd54321 in forum Classified Archive
    Last Post: 10-07-2004, 10:11 PM
  4. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
  5. cd changer interface
    By SKIDrow in forum General MP3Car Discussion
    Last Post: 05-10-2001, 10:02 AM
