Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 118
Thread: USB Relay Controller
  1. #31
    Registered User
    May 2003
    Quote Originally Posted by kiltjim
    OH! Or better yet! What if you could have the computer sending a signal to the card every once and a while. That way if the computer died, the card would automatically shut itsefl off. Wow, this is such an incredible idea! Why hasn't anyone else thought about this?
    The watchdog is already been partly coded on Ricky's card, thats even before the discussion of the autoreset for the PC some weeks ago
    The PC must send an $ON command to the card once every second, without this the relay card would then reset itself reverting back to the default relay states.
    Because at the moment, theres no apps to run the card this features have been disabled. I cant keep typing $ON every second on the hyperterminal
    Ill add a command to the card that can enable/disable the watchdog.
    Man you guys are slow with ideas
  2. #32
    Zac
    Zac is offline
    Feb 2004
    VA
    It would take another IO line, but couldn't you add a sense line and use that to determine if the computer is on or not? (Altho that wouldn't account for cras...ok I'll shutup again )
  3. #33
    Zac
    Zac is offline
    Feb 2004
    VA
    (edited last design a little)
  4. #34
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    So.. simple.. I want one! Quick! to the batcave! *dons his blue cape and jumps into a barrel of astroturf rocks*
    YOU'LL NEVER CATCH ME!!!!
    (I want one)
  5. #35
    found a couple of sites which may help with the development of the usb drivers controlling the baord etc
    http://www.touch-base.com/main.asp?item=25
    http://www.usb.org/home
    http://www.usb.org/developers/tools
    hope this helps and hell i want one too
    i have a little bit of experience with pic's so if you nee any assistance then gimme a yell
    T
  6. #36
    Zac
    Zac is offline
    Feb 2004
    VA
    Thanks for the links. The prototype is basically done so drivers/firmware aren't an issue anymore. I'm redoing the PCB layout (argh missing sparkfun's friday deadline (afaik that's how it works from reading the support forums) so it won't even get looked at until like next friday so I figure I have some time to fix it up a little bit more. The board is 3x3.3 so I'm might as well try to shave it down as much as possible to get the price lower :P
    As with most of my projects I got it to the point where it works and then kinda forget about it so it'll be nice to go all out and come up with a professional looking product.
    And for open-sourcing it I will more than likely throw a howto/tutorial type of page to put one together but it won't be anytime soon. Until then if you are interested in making one of these rather than buying an already made one look at Microchip's forums for tips and the sample code/schematics you can download that comes with the USB2 dev kit they offer. Once you get USB communicating, it's easy to add whatever you'd like. :P
  7. #37
    Registered User
    May 2003
    Quote Originally Posted by Zac
    What language did you write the windows apps in? Im trying to get the mpusbapi.dll in borland delphi, my good old pascal knowledge from UNI comming into some use. I got fed up with VB stuff, crap just wont work for me.
  8. #38
    Zac
    Zac is offline
    Feb 2004
    VA
    VC6. Sorry don't know delphi...search or ask in MicroChip's forums maybe? Do you know how to do the dll calls from Delphi? (Google turns up http://developer.novell.com/research...gust/04/02.htm which I think had sample code.) Then it should () just be as easy as looking at the sample C demo code to figure out what needs to be called and everything.
  9. #39
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Now can this be used to controle DIGITAL servos? Say for.........H/AC controles.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
  10. #40
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    No, this is only for relays. You probably want a servo controller card. I know for a fact that there are pre fabbed cards available. And from what I remember, its not that expensive.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  1. FAQ: Everything you need to know about your Xenarc
    By frodobaggins in forum LCD/Display
    Last Post: 10-12-2014, 10:58 PM
  2. WTB: Opus 120-150, DSSC controller, ITPS, USB TV, 256 Memory
    By clean customs in forum Classified Archive
    Last Post: 03-21-2005, 05:47 AM
  3. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  4. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 03:35 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
