+ Reply to Thread
Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 118
Thread: USB Relay Controller
  1. #41
    Low Bitrate TechToy's Avatar
    Quote Originally Posted by Zac
    Rough pcb layout. So rough it's just using eagle's auto route.
    If it works and it won't affect cost why **** with it eh?
    you may want to look at the trace sizes...
    they won't be able to support tooo much amperage...
    and if someone is gonna use this pcb design to controll a window motor or even power locks... the traces will burn of the board on the 1st trigger...
    also what is the specs on the relays you spec'd out for this design..
    you may want to do something like mix 2 types of relays... 4 hi-amp rating ones with 4 lower amp ones... i'd go at least 10 amp on the hi-amp ones and 2-5 on the lower amp ones...
    just my .02
    TechToy
    2005 Explorer
    Proudly using Centrafuse
    DWW-700M + Sony XM-SD46S &
    pre-amp, XM100D
    and Icom PC1000
    Yaesu 7100M
    Kenwood TM-641
  2. #42
    Zac
    Zac is offline
    Feb 2004
    VA
    I know, I redid the board earlier today. That was the first thing that changed.
    I'd be more worried about those little pins for the relays then for the traces now. :P
    (Relays: "16a, 24vdc"...not sure if I believe these claims or not but we'll see throughout my testing.)
  3. #43
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    Delphi...
    Hey im keen to do some delphi coding for this project.
    email at naresh@corporatecam.co.nz
  4. #44
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    Quote Originally Posted by kiltjim
    No, this is only for relays. You probably want a servo controller card. I know for a fact that there are pre fabbed cards available. And from what I remember, its not that expensive.
    Can u provide me with a link? I thought I saw someone saying thay could controle their amp gaines with this board.
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
  5. #45
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Pre-Built Servo Controller: http://www.seetron.com/ssc.htm
    Although, if you are looking at controlling an Amps gains, you are looking at a digital pot. Something like a DS1669. That would let you control the resistance by sending a low signal to either the up or down pins. You could do this through the serial port. And come to think of it, you could do it with a very simple program too. I might even have to add that to the program I am working on. The DTS, and RTS lines aren't used by anything I am using right now...
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  6. #46
    Zac
    Zac is offline
    Feb 2004
    VA
    Dude you don't know how much searching time you just saved me :P
    I'm gonna have to take a look at that DS1669 part
  7. #47
    Low Bitrate Bullwinkle777's Avatar
    Mar 2005
    Waynesville, Ohio
    I have an air ride setup on my car and was wondering if there was any relay controller (USB or what ever) that I could use to control it? It would be nice if it worked with RR so when I touch the screen it would close the relay and open it as I let off the screen.
  8. #48
    Feb 2004
    PA, USA
    You should probably search a little more too, though. I just threw that one out there as an example. I don't have the datasheet in front of me, so I don't know the step size of the chip. I do know its used as a digital volume control though.
    Quote Originally Posted by Bullwinkle777
    That would be pretty cool, but I don't think I've seen any with momentary control through windows. I know there are programs that will do it for a selectable amount of time. I don't really know how fast the program and relay wil respond, so you may not have the control you are lookig for.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  9. #49
    Mar 2005
    Waynesville, Ohio
    Thanx for the info kiltjim! It sucks that there isn't anything out there that will do what I'm wanting, but hopefully someone in the future will make something that will work. I'll keep my fingers crossed.
    Thanx again!
  10. #50
    Feb 2004
    PA, USA
    Like I said, I think the problem is going to be the repsonse time of the software talking to the hardware, then the hardware talking back to the software, etc. I do plan on incorporating a "momentary" option, but it will only be momentary because it will be a rapid on off, at a given interval (say, 1/2 a second, or more) But I don't know how well that would work for what you need it for.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
+ Reply to Thread
  1. FAQ: Everything you need to know about your Xenarc
    By frodobaggins in forum LCD/Display
    Last Post: 10-24-2009, 06:44 PM
  2. WTB: Opus 120-150, DSSC controller, ITPS, USB TV, 256 Memory
    By clean customs in forum Classified Archive
    Last Post: 03-21-2005, 05:47 AM
  3. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  4. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 03:35 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
