Page 6 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 60 of 118
Thread: USB Relay Controller
  1. #51
    Zac
    Zac is offline
    Feb 2004
    VA
    just do the timing on the PIC side of things?
    (to pic: "RELAY1_ON,2000" turn relay on for 2s then back off)
    (to pic: "RELAY1_ON" turn relay on until command to turn off)
    Or just have the OS send relay on when initial button press then when released send relay off....but yeah the timing issues are a big worry but I haven't really tested latency yet.
    (Basically these ideas were for my window/moonroof but could be applied to bags if your controller is as simple as my friend's....it's just a bunch of toggle switches so you could easily replace the switches with relays.)
  2. #52
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by CHUPACABRA
    Can u provide me with a link? I thought I saw someone saying thay could controle their amp gaines with this board.
    Servo controller: http://www.seetron.com/ssc.htm Allows you to control up to 8 servos via VB through the serial port.
    Want to:
  3. #53
    Registered User
    May 2003
    Im a little confused about the latency time. How quickly does this bag thing need to be activated/deactivated?
    Im currently testing my USB card and at a click of the mouse button the LED lights up instantly and off instantly when released.
    Im sure it have some latency in ms, it is certainly fast enough such that it cant be seen.
    The control apps is written in delphi 2005, PIC is written in C running the USB in fullspeed. PC is a dual processor 1GHz P3.
  4. #54
    Apr 2005
    It looks like a PIC with a ULN Darlington Array with a bunch of relays on the gpios. You're going to need some protection on those relays, though (if you use this design).
  5. #55
    Registered User
    May 2003
    The ULN drivers already have built in clamping diodes, thats the beauty of it.
  6. #56
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    ULN drivers
    肚子笑痛了
    S60 Install
  7. #57
    Registered User
    May 2003
    ULNs
  8. #58
    Zac
    Zac is offline
    Feb 2004
    VA
    ^what they said :P
  9. #59
    Low Bitrate Stonewall78's Avatar
    Dec 2003
    Calgary, AB
    Quote Originally Posted by Chris31
    ULNs
    I get stuff in with blow 2003's all the time. Stupid installers forget to put a diode on the horn relay all the time
  10. #60
    Low Bitrate Bullwinkle777's Avatar
    Mar 2005
    Waynesville, Ohio
    Quote Originally Posted by Zac
    "relay on when initial button press then when released send relay off" is EXACTLY what I'm looking for!!!!!!!!!
  1. FAQ: Everything you need to know about your Xenarc
    By frodobaggins in forum LCD/Display
    Last Post: 10-12-2014, 09:58 PM
  2. WTB: Opus 120-150, DSSC controller, ITPS, USB TV, 256 Memory
    By clean customs in forum Classified Archive
    Last Post: 03-21-2005, 04:47 AM
  3. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 01:33 PM
  4. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 02:35 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 04:50 AM
