Very nice work!!!
I have been working on this for quite some time, but I have finally finished it. After abandoning the serial interface for several reasons I came up with this:
There may be some enhancements in the future, but for now this works great.
Connection:
- The parts list for the connection is:
- 2 10k resistors
- 1 15k resistors
- 1 2.2k resistor
- 1 .033uF capacitor
- 1 +12V to +5V regulator (e.g.) 7805A
- 1 2A2904 transistor
- 1 USBMOD3 (the best price I found was at http://www.futurlec.com/USB.shtml )
- A 4 or 6 conductor modular phone jack (or you can rip apart a phone cord)
- A small enclosure (such as this ) to make things neat.
Look for the thread on the accompanying software in the software forum.
The valentine 1 is a radar detector, a very popular one... this displays its output on your carputer.
e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
sold it all... :-(
Coming Soon - 2007 BMW 335i UMPC install
Awesome work zPilott!! I'll have to see if I can make this one work with my V1
Does the concealed display need to be attached in order to get the output signal?
Thanks for reminding me, I should have said this before. The current design works ONLY ON ITS OWN!!!!!!
DO NOT CONNECT THE REMOTE DISPLAY
(sorry about that, just wanted to make it clear that running a splitter and connecting the remote display MAY cause problems)
I am working on modifying things to allow for that, or for putting an in and an out jack on the board for connecting the remote display.
That's what I figured... just wanted to make sure
You can do what I did on one of Jim's designs and just put in a 2-pin jumper or single position DIP switch inbetween that resistor and +12V (or in this case, +5V). Not as elegant as an input/output port, but it works.
Where do you hook it to the pc ?
[H]4 Life
I'm a lesbian too.
I am for hire!
nevermind, wasn't looking at the usbmod3Originally Posted by frodobaggins
just the schematic
[H]4 Life
I'm a lesbian too.
I am for hire!
