Does this really work?
Did you build it and tried it?
i searched some infrared recivers and transmitters a long time ago (When i had a color Handspring visor... ahhh...) and these things were much complex than this little circuit...
Check this out!
This is a schematic for a IR module that costs, well not $1 maybe $3, and probably works with VIA's Mini-ITX onboard infrared connectors!!! I will build it and check for you! It doesnt cost much so if anyone finishes it before me, will not be mad
http://www.hardwaresecrets.com/article.php?id=86
I'd be really happy if that does work... but in the manual for my epia it says that the FIR and CIR headers are NOT standard (and to consult them for reference designs), like it is on most motherboards... so if it's designed for a standard IRDA header like you would find on other motherboards, then it may not work on the VIA boards... of course, I only have an epia 800 so it may be different for different models...
Printed! i think i'll head down to radio shack to see if they have the parts, i have a few remotes i'm not using
500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
Installing in Monte
1994 Ford Probe SE beater/Girlfriend's car
1995 Monte Carlo Z34 Engineless carPC
very interesting!!!
any results? bout to go nutz with Ipaqs in the car![]()
92 Subaru Legacy Wagon
Epia MII12000 :D
Morex 80W
120G External HDD
16x2 Charater Display
Creative IR Remote
VIA Sereniti 2000 Mini ITX Case
7.2Ah SLA Tank
PCMCIA 802.11b
256DDR Ram
Diamonds are for girls- wise men follow the stars
Have bought the components, but high fever and this bloody headache doesnt allow me to concentrate and built it![]()
I've made a very similar circuit for a microcontroller/universal remote circuit. Looks like it'll work. Problem is that the cheap IR LEDs aren't very powerful and are required to be right next to the receiver.
i think i'll try this also.
i have a treo 650 and this is a good way to transfer pics or an mp3 or two.
thanks.
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
has anyone tried to get this to work?
thanks.
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
