Results 1 to 10 of 14
Thread: Remote starter?
    Constant Bitrate Juliemac's Avatar
    Upstate NY
    Remote starter?
    i was hoping to inteface a remote starter control to turn the car alarm on/off and start up the PC. Any suggestions?
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Modifying any commerical unit would be a pinch. Can you give us some info on your current setup?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Here's my guess: since the remote starter would start the engine, it should therefore power the ACC line. Have your SDC monitor the ACC line and you're set.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Your remote start or security system should have instructions to interface with the other (if they are aftermarket). Sometimes they want a momentary pulse, and some of them want a solid signal, ground or positive. You can always turn you system on using the pulse coming out of either to the system. But we would need to know which power supply you are using.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Yep - monitor Accessory is a good one.
    I opted for a remote which included an AUX button (aka: trunk popper). The problem with this is that it's a momentary switch. Which can be a PITA to hook up to a shutdown controller, unless you're good with circuits. (keep in mind, I'm a newbie at circuit design, but I have a working shutdown controller which does this)
    Trunk poppers work wonders if you're only using it to toggle the power switch header on your mobo....
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Upstate NY
    My system consists of a shuttle SK41 @ 1.8Ghz, 40 GB hd, 500 mb Ram, 8" LCD with touch screen and a Mystero 4.5 that has been modified.
    It also has a 40 pin microcontroller with 30 I/O and 4 A/D's.
    One of the A/D's will monitor the battery supply for low voltage (and run the SDC)
    One will check the power out for the PG signal.
    One of the I/O will look for a signal from a remote starter to turn off the alarm (4 I/O) and bring the system out of hibernate.
    It also has a 2*16 LCD mounted in the dash display for status reports.
    This system definately has the Frankenstien effect. All I wanted was an MP3 player
    The remote WILL NOT start the car, just control the system in the car. I still like to turn the key!
    Feb 2004
    PA, USA
    If you have a mPU it should be easy to do. You can use the security system to turn off the security, have the mPU monitor that.
    'Door unlock' goes to ground, it flips a relay for a given time to start the car, but not without checking to see if the car is already started.
    The you have it pulse your SDC to start the computer. Or even have the relay as a DP, and have that hold the 'on' button for you.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    How about something simple like this?
    I know there are other versions out there. I got a ton of them when I googled "remote RF hobby"
    Want to:
    Upstate NY
    Good catch. I googled and found this.
    http://electronickits.com/kit/complete/elec/ck1616.htm
    Ordered tonight. Man this is a fun project. I spent today re-wiring the dash and running the new HD power cables to the location.
    Upstate NY
    I got the kit today. The PCB is very well produced and easy to assemble (1 hour). Started first time. It has 4 10a relays that can be momentary or toggled (jumper).
    Greater than 300' range.
    It draws 8ma (0.008a) when all off and adds ~40ma with each relay keyed.
    When set to toggle, the output can turn the CPU on or off.
    Good for beginner!
  1. Remote Starter & Carpc Startup
    By mattdisaster in forum General Hardware Discussion
    Last Post: 04-21-2005, 03:12 AM
  2. FS,FT remote car starter
    By maximilian in forum Classified Archive
    Last Post: 05-10-2004, 07:26 PM
  3. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  5. remote pc starter
    By oddcomp in forum General Hardware Discussion
    Last Post: 08-26-2003, 10:17 AM
