Results 1 to 7 of 7
Thread: Need to power on a laptop remotly
    Apr 2005
    France
    Hello,
    My CarPc will be a laptop but placed under a seat. I would like to know how i can perform a start button or remote when i turn on the car or perhaps with a button on the car mainboard (maybe thru USB)
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    you have a few options,
    fist, how are you going to power it? an inverter? or a incar laptop charger?
    you could just put a switch on those, and set your laptops bios to boot on power resume.
    you could also set to power on keyboard so when you press a key it poweres up, or just open it up and solder wires onto the switch contacts and put a momentory switch somewhere that you can get to it.
    Apr 2005
    France
    Thanks Dan,
    I've got a laptop charger for this.....
    I will try the power resume option if bios could...
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    What you really need to do is for 'remote laptop'
    laptops very rarely have the boot on power resume as they don't suffer from power cuts thus it is ommitted from the BIOS. What you really want is an anutomatic system. There is a very nice thread about it somewhere using a realy hooked up to the power button. Search and ye will find.
    Dec 2004
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I won't be able to try it till next week when I get my docking station, but I'm going to try it with a 4n25 optoisolator. Basically a photransistor and led in one package. So you can connect the two circuits without electically coupling them. You apply 5ma to the led side and it allows current to flow through the transistor on the other. They are pretty cheap (~25c) and I'll "press it" by using a 555 monostable.
    Still need to work out a thing or two, but I'll post how it turns out.
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    My carputer laptop has a busted screen, and is installed permanently, so i opened up the case and soldered some wires to the power button. The wires are connected to a relay that automatically starts it when I start the car. I also have them connected to an oem switch it the dash, so I have an override.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  1. Remote laptop startup
    By ambush in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2008, 03:28 AM
  2. laptop power when in standby..
    By hotponyshoes in forum General Hardware Discussion
    Last Post: 02-17-2005, 06:44 AM
  3. laptop power on...again
    By Lucky in forum Power Supplies
    Last Post: 12-30-2004, 08:05 PM
  4. laptop problems / power issues
    By daguju1der in forum General Hardware Discussion
    Last Post: 07-21-2004, 06:44 PM
  5. prob with power to laptop
    By cubanmoses in forum Power Supplies
    Last Post: 08-19-2003, 09:21 AM
