Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Heeeelllppp!!
    May 2005
    Heeeelllppp!!
    Hello everyone ! , i would like to know if anyone know where can i find a diagram with the specifications to make a cifford cable , the cable that conects the alarm to the computer !!
    thankes !
    Lsilva
    Registered User
    May 2003
    Theres a MAX232 chip equivalent in that little box.
    All it does is translate the TX/RX TTL level into an RS232 level for the PC. If you look at the clifford connector you find theres 3 pin, (RX/TX), GND, +V
    As for the circuit, no I havent seen one and I dont think anyone had bothered to draw it.
    May 2005
    thanks , but i wont to make one , because were i live is very expinsive ! and if i make one is more cheap !!
    anyone has the draw ?!?!?
    Registered User
    May 2003
    Ok man, give me a few days...Ill post some pics for you.
    May 2005
    hei man thank you , i will wait for the pictures !!
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I'm not sure exactly what you are talking about, but it sounds like you might want to take a look here http://www.compsys1.com/workbench/On...3_adapter.html
    you should be able to use one of these adapters (i would recommend A232DBH ). Make sure you know if you are ordering the assembled board, or an unassembled kit.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    New York
    Just a little side note.
    Your talking about the Clifford Alarm units, right? Well, my question is this, are you talking about the version that has PC software for program or the bitwriter units? Cause if the alarm is bitwriter compatible, then you would have to write your own programming software for the alarm.
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
    Registered User
    May 2003
    I think its the cliffnet hes on about.
    May 2005
    yes is the clifnet , im looking for de diagram of the cable ,to make one !!
    if anyone know were can i find one !?
    thankes
    Lsilva
    Registered User
    May 2003
    Im trying, im trying...
