Results 1 to 7 of 7
Thread: Smallest Motor
    Nov 2003
    Smallest Motor
    Does anyone know where I can find a small motor that would be able to move a 7" lcd up and down, like not up and down, but tilt up and down. I was looking for a motor possibly the size of the circumference of a AA battery, and 2 cm long, that's all the room I have for one. Thanks.
    -=Chevy CarPC=-
    ETA: When i get more time
    -Custom Fiberglass Case
    -Epia M-10000 Nehemiah 1Ghz
    -Sony CDRW-DVD Drive
    -Seagate 120mb Hardrive
    -Opus 90w Power Supply
    -Lilliput 7" LCD
    Registered User
    May 2003
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    i'd use a servo as you can leave it turned on and then it will hold it up.
    Look for a ballraced metal gear servo with alots or torque. Landing gear servos are normally pretty good and you can alsways use two if you get two identical ones. To stop them fighting each other you could also wire the position encoder from one to both servos (reversed on one if you have them facing each other). this will mean they both report the same position but you could eaqually jsut use trimming pots in the control circuit. I posted some simple servo control circuits somewhere and bugbyte has a flip up monitor he controls with a stamp. (my circuits are cheaper and require no programming which i how i like em!)
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Yea they have micro servos that are pretty small.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Apr 2005
    Chicago Illinois
    try a hobby shop for some small RC servos. shouldnt cost you more than 30-40 bucks each servo
    gti is offline
    Dec 2004
    servos are ideal for automating stuff, most have 3kg torque, and you can mod them for contunous rotation if you need to.
    If there is any concern you may strip the gears then get a better servo.
    Mar 2004
    Quote Originally Posted by WebDog
    micro servos have **** all torque mate. They are designed for speed to actuate control surfaces.
    Best go with a nice beefy undercarriage servo.
  1. Smallest case for one PCI card and M10000?
    By daem0n in forum General Hardware Discussion
    Last Post: 04-26-2005, 06:33 PM
  2. reversable motor for monitor?
    By more mods in forum General Hardware Discussion
    Last Post: 12-12-2004, 05:20 AM
  3. Mobile video in California
    By dacndar in forum LCD/Display
    Last Post: 11-30-2004, 03:36 PM
  4. Can I power a LaserDisc motor with the OPUS 150w?
    By afr0puff in forum Power Supplies
    Last Post: 02-27-2004, 09:28 PM
  5. DC motor control - HELP
    By Termite in forum General Hardware Discussion
    Last Post: 02-19-2004, 04:09 PM
