Results 1 to 10 of 14
Thread: Pc integration for Smartire pressure system or Back up sensors
    Mar 2004
    New Jersey
    I was wondering if anyone tried to integrate the Smartire Tire monitoring system to a car pc? How hard would it be?
    What about those back up sensors for the bumpers that we all see on ebay?
    Thanks again!
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I'm planning to do something with backup sensors, except I'll install 2 sensors in the front and 2 in the back. Still don't know how I'll manage to do that, but I will eventually
    Mar 2004
    New Jersey
    I cant wait to see the finished product.
    I am going to purchase one of those units on ebay and see how it communicates with the display.
    -Jack
    Low Bitrate angusn's Avatar
    Mar 2005
    Connecticut
    Funny (kinda) related topic
    My dad's 2000 Corvette has some integrated tire pressure gage and it's very flakey. When he first got it (new in spring 2000) it misred the tire pressure and wouldn't let the car go over 50mph. That sucked for me, 'cause I wanted to see what the car would do!
    Are you thinking of getting the voice to read you the tire pressure if it gets below a nominal value?
    "Right rear tire pressure is low. Car needs air badly!"
    Car: 1997 VW Passat TDI moving to
    1985 Mercedes-Benz 300D
    CPU: HP ePC 1gig/256meg/250 gig
    Status: Ghetto Install w/Inverter,
    Xenarc & GPS & RadioShark
    ToGo: DC-to-DC conversion, Grease conversion
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by Kamakazie2
    Thanks again!
    Is smartire a specific brand of tps? I was reading an article on autospeed.com about splitting ABS and traction so you can disable TC via switch without loosing ABS. (I've wanted that for awhile) Long story short, reading up on the sensors gave me an idea.
    If you have for wheel speed sensors, you can use them to measure (roughly) tire inflation. Many oem systems do just that. I think the system is usually called Differential Tire Pressure Monitoring (DTPS). They compare the 4 speed signals, if one is faster, the tire is smaller and therefor underinflated. It doesn't help if they all lose an equal amount over time though.
    Shouldn't be to hard with a PIC. It's on my list of things to do
    Mar 2004
    New Jersey
    Quote Originally Posted by shotgunefx
    I like that idea, however how would we differentiate when the car goes around turns? Maybe if we link the tire speed based on side instead of comparing with all 4.
    Smartire is a system that you install in the rim prior to installing a tire. Its a band that measures inflation and wirelessly transmits the info to a reader.
    http://www.smartire.com/
    -Jack
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by 0l33l
    don't forget to mount some in the sides linked up to a warning sound or a camera!
    Apr 2005
    Boston, MA
    Good point. Well I suppose you would see a change in both tires so that could be an input. But I think the because the baseline is averaged out over quite an amount of time, turning I would think would be factored in by the averaging.
    You could always use an accelerometer. I've got a Memsic one. I haven't installed it yet (but have played with it) as I don't know if I'm going to use it to measure vehicle movement or as a tilt sensor for the steering wheel.
    I'd really like to have my driving lights turn with the steering wheel. They make steering sensors (Basically big potentiometer) but they are big, big bucks. The problem with the accelerometer I need to work out is that my wheel turns multiple times. Not a big deal to calibrate out, but just haven't had the time. Plus I have to fabricate brackets for the lights.
    Mar 2004
    New Jersey
    I would love to take that idea and relate that to my reverse camera. As you turn the wheel in reverse it will pivot the camera to see where your car is going.
    -Jack
    Apr 2005
    Boston, MA
    Way ahead of ya! (Note the servo)
    Another easier option (that I might take) is to wire it to your blinkers and just have it deflect when you use them.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. Super small PC barebone system... your views?
    By Techy Ben in forum General Hardware Discussion
    Last Post: 11-23-2003, 02:32 PM
  4. My PC plans - anything wrong with this system?
    By mx270a in forum General Hardware Discussion
    Last Post: 09-02-2003, 07:32 PM
  5. controling ac system with car pc
    By sugarmychurro in forum General Hardware Discussion
    Last Post: 05-21-2003, 02:17 AM
