Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 61
Thread: Steering-Wheel Controller
  1. #11
    Oct 2002
    If the device reading the resistor divider is high enough impedance it should not interfere
    with the factory operation.
    opamp buffer with unity gain if all else fails.
    Be prepared that the resulting voltage you may see will vary with engine running /not
  2. #12
    how do they normally get the wires through the steering column with prevent them from from becoming tangled or broken when you turn the steering wheel?
  3. #13
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by Dave_Perth
    Good Question!
    Probably the same way the run the wires for CC and Airbags... Well, I'm off to dismantle my steering wheel!
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  4. #14
    Maximum Bitrate DeltaFX's Avatar
    France
    Imagine a toilet paper roll... or wristwatch spring. Its the same. There are no moving contact, cables are simply coiled. You turn the steering wheel to the left, it will tightend the "coil", to the right and the coil becomes loose.
  5. #15
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Lightbulb
    I like this controller as well, and yes it is made by Sony. This guy has some more info on it.
    http://www.armory.com/~charlie/empeg1/
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  6. #16
    Oct 2003
    Quote Originally Posted by stevieg
    Yep it's quite straight forward, though not 100% reliable with IR as you need the receiver in line-of-sight. You can get the reciever from www.irman.com and it comes with software to automate the IR functions.
    Wow! What do I need to do to get this to send keystrokes to windows!? I want this now - I have been wanting a steering wheel controller for so long.
    Dan
  7. #17
    Oct 2003
    Well, I'm a little disappointed. I got the Blaupunkt controller in the beginning of the post, but the IRman doesn't recognize it's signals. I'm thinking it's out of its frequency range. I'm going to do a little more experimentation, any ideas would be appreciated.
    Dan
  8. #18
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by dmurray14
    Dan
    Ya - that's one finiky remote!
    I used one of these: http://www.radioshack.com/product.as...5Fid=276%2D640
    (38kHz) (Sorry - no experience with IRMan, but mine is a serial port device, the same as IRMan...)
    And this LIRC definition (using WinLIRC): http://lirc.sourceforge.net/remotes/blaupunkt/
    I also had to fiddle with the eps to get it to recognize the remote (I think it's based on the speed of your CPU - I set mine at 8)
  9. #19
    May 2005
    Quote Originally Posted by davesaudio2
    Thats what i'm thinking. My problem is not interfering with the existing circuit but that i am using the stock headunit. I can't have the steeting wheel buttons controlling both the HU and the car PC at the same time. What i really wish i had was some way to make the steering wheel buttons automatically switch to controlling the CarPC when the headunit is set the the AUX input and then back to controlling the HU when its not on the AUX input.
  10. #20
    May 2005
  1. Steering Wheel ADD-ON Controls w/o System
    By ChaCha in forum General Hardware Discussion
    Last Post: 11-16-2012, 02:19 PM
  2. GM Steering wheel control interface
    By S7347H in forum Input Devices
    Last Post: 04-14-2005, 02:17 AM
  3. Cell phone in steering wheel, IS this possible?
    By sansoo24 in forum PhoneControl
    Last Post: 04-06-2005, 11:47 AM
  4. Installing a LCD into a steering wheel..need help!
    By DrSergioDJ in forum Fabrication
    Last Post: 01-26-2005, 04:23 PM
  5. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 05:27 AM
