Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Car Start on Finger-Print Recognition?
    Newbie tyRion's Avatar
    May 2005
    Ireland
    Question Car Start on Finger-Print Recognition?
    Would it be possible to do this?
    Either 1) Wire a Finger-Print scanner to the pc, so it only boots if a fingerprint is picked up, then start the car, via a line out(LTP?) to a relay, would mean PC would be on before Car PC
    Or 2) Wire the scanner to the relay for starting the car directly, then the PC boots like normal
    In the first case you'd need a button to start the car, but in the second one it'd just start when the print was recognised.
    These sites may be helpful, Print-Readers or Bio-link U-Match
    Edit: I also just found this, which may be of some use, considiring it dosent need the PC to be on
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Try searching the forums with terms "fingerprint". There's a big thread on the MS fingerprint reader there.
    Want to:
    Nov 2004
    problem with going straight from the scanner to ignition is that you would have to have a dedicated system. one idea is that there are scanners for home doors that controll relays to unlock the door. you may try something like that and just run the relay connection to the ignition. personnaly id just run straight through a computer with biometric login and a startup program signaling relays through one of its ports.
    May 2005
    Ireland
    Ok, I wrote a program to put on the CPU of the UniFinger™ SFM3000.
    Its written in BASICA or GW-BASIC which is the only code I know off by heart, here it is, please point out any mistakes
    Code:
     10 if in5<>1 and in4=1 let x=1 else let x=0
     20 in in1=1 and x=1 let y=1
     30 if v=1 let y=1
     40 if x=0 let y=0
     50 let v=0
     60 gosub 170
     65 if in3=1 and in2=1 let y=0
     70 if y=1 and in2=1 goto 90
     80 goto 10
     90 let y=2
    100 let v=1
    110 for w = 1 to 50
    120 if in3=1 goto 10
    130 next w
    140 gosub 170
    150 let y=1
    160 goto 10
    170 if y=0 let out1=1 else let out1=0
    180 if y=1 let out2=1 else let out2=1
    190 if y=2 let out3=1 else let out3=1
    200 return
    Here are the varibales and inputs I'm using (you can use 8, which i have 5 in, 3 out, though out1 is probabally unnecissary)
    Code:
    in1	Thumbprint Match signal
    in2	On/Off PTM stitch
    in3	Engine running sensor
    in4	Drivers Door PTM (Closed gives value of 1)
    in5	Alarm Indicator singal (1 is alarm on)
    out1	Off
    out2	On/Drive
    out3	Ingition
    v	Remember ignition position from loop
    w	loop
    x	Door and alarm OK
    y	Key state
    The line ins or outs may have to be linked to relays or optoisolators
    Constant Bitrate emdzey01's Avatar
    Jan 2005
    san fernando valley
    just remember to take care of your thumb... if someone cuts it off they can run away with your car
    Brushed Metal for Centrafuse 1.4
    Brushed Aluminum for Centrafuse 1.4
    xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    Quote Originally Posted by emdzey01
    we will need to keep a spare thumb ;-)
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    actually, you can bypass the fingerprint biometrics with a gummybear.
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    It would be proably be best to use an aftermarket car remote start system. There is more to starting most cars then just the ignition wire. Many remote starts can be activated with a neg pulse and that would cover all the relays, safety shut offs, starting and stopping the car.
    Jan 2005
    san fernando valley
    gummybear? ill have to try that out sometime.
    and yeah, you should keep spare thumbs in your wallet, just in case you leave yours inside your car.
    Sep 2005
    Fingerprint car immobilizer
    Hello,
    look what i found...fingerprint to start cars..
    visit www.automobile-security.com
    Looks real..
    what do u guys say?
  1. can I power a car stereo with an ATX PSU?
    By Fourgig in forum General Hardware Discussion
    Last Post: 09-08-2009, 07:40 AM
  2. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  3. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
  4. New toys for the pc car
    By gizmomkr in forum General Hardware Discussion
    Last Post: 02-06-2002, 05:55 PM
  5. System Restarts whenever I start my car
    By Blue Falcon in forum Power Supplies
    Last Post: 06-25-2001, 06:15 PM
