Results 1 to 5 of 5
Thread: AT Keyboard cable hack *input needed*
    Low Bitrate c4shm0ney's Avatar
    Jul 2004
    Indianapolis
    I tried extending an old AT style keyboard cable using CAT5e cable, there are 4 wires plus some copper strands in the cable. I want to know if the copper is a ground wire for the keyboard. Originaly I suspected it was only included to increase the strength of the cable or possibly shielding however after the mod the keyboard does not work. Can anyone confirm my suspicion that the strands are for grounding?
    Elsewhere
    Quote Originally Posted by c4shm0ney
    Why don't you hjust get an extension for an AT keyboard?
    This place has a 25-footer for $11.00: http://www.cable4pc.com/kbdcbl.htm
    How about the Wiki?
    FLAC evandude's Avatar
    Mar 2005
    Maine
    there are 5 pins in an AT connector, of which four are used. ground is one of the pins, but in many cases it is likely that the shielding is a ground too, connected to the metal outer part of the connector. It's unlikely that not including it would cause a huge problem, other than the fact that if it's not grounded it won't be a very effective shield.
    I would say check your wiring, and if you are sure it's correct and nothing is shorted, and still doesn't work, then go ahead and connect the shield braid as well, there's no harm in trying it.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Jul 2004
    Indianapolis
    Quote Originally Posted by DarquePervert
    I didn't like the ugly beigh(sp?) cable.. Looks much better with what I have on it now and is easier to conceal.
    I a bit puzzled as I counted only 4 wires in the cable, I'm guessing the braid is wired to a pin at the other end of the connector. I'll try that and report back.
    Feb 2000
    AZ
    The big question is what are you running that needs AT?? Thats 1998 and before computer stuff there...
    99 ram 5.9 turbo
    P4 2.0, MicroATX, Audigy2nx, Monster Cable / Alpine.
    Coming soon: Indash motorized, 5.1, dvdrw, gps, bluetooth, wifi, and more!
  1. virtual Keyboard 1.0
    By SilentAdmirer in forum V.O.I.C.E.S
    Last Post: 05-08-2007, 09:21 AM
  2. Sky navigator remote as keyboard??
    By rhinoofstockton in forum Input Devices
    Last Post: 11-13-2004, 08:18 PM
  3. Keyboard problem in skin
    By gyro in forum NeoCar Media Center
    Last Post: 11-12-2004, 07:13 PM
  4. Vga to Svideo cable?
    By si2001 in forum LCD/Display
    Last Post: 11-01-2003, 02:33 PM
  5. extending the cable length of keyboard?
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 07-25-2000, 04:53 PM
