Results 1 to 7 of 7
Thread: 110v or 220v AC to 12vDC converter
    Newbie jessebs's Avatar
    Jun 2005
    Texas
    If I made a couple of these, would anyone be willing to buy them?
    Basically, I use it to power my carputer usings its internal (12vdc) power supply, so when I bring it inside for development, I dont have to bother with connecting a standard ATX power supply.
    It is somewhat similar to http://www.hobby-warehouse.com/in10ashepows.html in functionaliy (but not adjustable output).
    Not sure the exact ampres out yet, but it will be at least 10
    Price for such a unit would definately be <$50, Probably closer to $20 or $30.
    If anyone is really interested, I can look into this and estimate the price better.
    [###########--] 85% complete - Software Installation
    To Do: Complete Voice Recognition, transfer hardware into car and wire.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you can already buy power supplies that are designed to run car accessories indoors... typically used by HAM radio operators...
    http://store1.yimg.com/I/teptronics_1851_77612990
    you can get them with 10-20 amps output for reasonable prices... so you'd have to at least beat the price of those... (do a google search for "13.8V supply") not trying to rain on your parade or anything, because if you CAN sell them for $20 or $30 then i'm sure you'll have little trouble finding buyers on here. (including myself, perhaps)
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Jun 2005
    Texas
    Power Converter is a link of how I made mine. If i marketed it, i would make it look alot better (and be safer).
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I am very interested for <$50 (if you can keep it small). I use those 13.8V 3A-5A's at work all the time. We also use 10A ones but they are HUGH weigh A TON and cost $100+.
    7A should easily do it. The biggest requirement is small size and low heat.
    I really want it set up so that the 110V-13.8V is inside my shuttle cube (along with my Carnetix 12V regulator) and on the back there is a standard PC plug connector (along with a seperate connector for car battery input). That way when I am visiting someone, I can simply pull my CarPC out of the trunk and plug it into their TV to show-off my huge DiVX library of movies and TV running a full-screen interface on their TV!
    Jun 2005
    Texas
    This is just a modified atx powersupply, so size and everything is that. Cost was going to be the price of the powersupply, plus my time (but not alot).
    I dont think this is the solution you are looking for, sorry. Maybe try searching for a 1u atx power supply?
    Nov 2004
    L.A.
    Well, in that case, have you ever heard of anyone making an ATX Y-Splitter with relays? I was thinking if the AC/DC is providing power, all of the ATX lines would be disconnected from the DC/DC, and if it is not then all of the ATX lines would be disconnected from it so the DC/DC can work and not blow up the AC/DC.
    A switch (rather than relay) solution would be fine too, but where could I find a 2-position switch that can change all ATX lines (9 lines minimum) with enough amperage?
    Jan 2006
    Sales Manager
    Hello everyone...as brief as I maybe. I am an American manufacturer of 12volt power sources [110vac to 12vdc from 30amps to 80amps].
    My primary market is the RV Industry but I'd like to diversify into the Automotive Industry.
    As many of your questions imply...you're looking for an inexpensive 12volt Power Supply and I have them.
    Feel free to contact me directly at jsalvo@progressivedyn.com
    I'd like to find out how to become affilliated with your industry so I won't have to find every chat room forum to attract business. Somehow find a distribution network to become associated with.
    Thank you and best regards...Joec.
  1. powering m1-atx dc via power outlet (USA 110V AC)
    By dtran01 in forum Power Supplies
    Last Post: 01-13-2006, 11:27 AM
  2. Power Converter
    By jessebs in forum Power Supplies
    Last Post: 06-24-2005, 03:37 AM
  3. FS: Car Power Point , PSU, Power Supply DC - AC Converter
    By m_lazell in forum Classified Archive
    Last Post: 03-21-2005, 05:11 PM
  4. WTB 70-75Watt 120 AC to 12VDC Power Brick
    By komarak in forum Classified Archive
    Last Post: 12-23-2003, 08:41 AM
  5. DC -> AC converter question
    By BRINET in forum Power Supplies
    Last Post: 03-25-2002, 03:21 PM
