Page 1 of 9 123456789 LastLast
Results 1 to 10 of 81
Thread: LEDs for 3rd Brake Light
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Idea: Convert ugly third brakelight to LED while also reducing rattles.
    How: Remove third brakelight. Get LEDs. Run wires. Done. (That's the idea atleast)
    Parts: I used 10mm 5000mcd LEDs I got from Ebay.
    Code:
    Product Description
        * Emitted Color : ULTRA RED
        * Size (mm) : 10mm
        * Lens Color : Water Clear
        * Peak Wave Length (nm) : 640 ~ 645
        * Forward Voltage (V) : 1.8 ~ 2.2
        * Reverse Current (uA) : <=30
        * Luminous Intensity Typ Iv (mcd) : Average in 5000
        * Life Rating : 100,000 Hours
        * Viewing Angle : 20 ~ 25 Degree
    Absolute Maximum Ratings (Ta=25&#176;C)
        * Max Power Dissipation : 80mw
        * Max Continuous Forward Current : 30mA
        * Max Peak Forward Current : 75mA
        * Reverse Voltage : 5~6V
        * Lead Soldering Temperature : 240&#176;C (<5Sec)
        * Operating Temperature Range : -25&#176;C ~ +85&#176;C
        * Preservative Temperature Range : -30&#176;C ~ +100&#176;C
    Before:
    The LEDs:
    Sodered:
    After:
    Problems: Need to be lined up perfectly. Need a case.
    Want to use the material these guys used on the bottom for the diffuser:
    [Edit]:
    This is a great LED calculator.
    Shave LEDs
    Current Status 1
    Current Status 2
    Current Status 3
    The 10mm 5000mcd LEDs are NOT bright enough unless they are looked directory on.
    Use 10000mcd s-flux LEDs.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    in the description you stated that you used 10 LED's, I only see 5 in the pic. How many did you end up with?
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    You know you could just buy a led brake light very cheap do you?
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by binary.h4x
    10mm
    For the dumb americans: that's 0.393700787 inches
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by MaleBuffy
    I'd rather make one myself
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by 0l33l
    10mm
    i r teh reading n00b
    Jul 2004
    Berkeley, CA
    Its ok
    BTW: I've got 100 of those LEDs. Got mine for $15 shipped
    15 cents a LED.... can't beat that
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    0l33l, I'm interested where you ordered LEDs from...
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by anky1
    ebay
    He had one acution for $12 with like $7 shipping and one for $15 shipped. You can figure out which one I got.
    I think I'm going to be overvolting these LEDs a bit. Instead of giving them 2.2v, I'm probably going to be giving them 3v. Anyone want to advice agains this?
    Apr 2005
    NJ
    thanks for the link 0l33l just ordered 100 for myself... I appreciate it
    Shameless plug: check out my thread again for new hardware and screen molding!
    Hello! VW Golf 1.8t
  1. How many does it take
    By veedubya in forum Off Topic
    Last Post: 06-03-2005, 01:15 PM
  2. BU-303 Dim Light????
    By KingsDude in forum GPS
    Last Post: 02-12-2005, 10:23 PM
  3. My bright white light mod
    By rvk2 in forum Fabrication
    Last Post: 01-16-2005, 11:37 PM
  4. How Many Does It Take...
    By mp3z24 in forum Off Topic
    Last Post: 09-19-2004, 11:54 PM
  5. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 12:19 PM
