Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Motor circuit with reverse
  1. #21
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Found something else that might interest you.
    This kit (which is based on an L293D), let's you replace the electronics of a servo and turn it into a motor. Basically you give 5v to one wire to go one way, 5v to another to go the other. You should be able to rig it so you can control it with a NO and NC switch.
  2. #22
    Aug 2005
    Quote Originally Posted by shotgunefx
    Correct me if I'm wrong but bascially this controller can be hooked up to a servo motor and a switch that can be used to control the servo without a separate controller? I'm looking to build a screen that can be raised or lowered by 1 servo using a push button switch. Will this work product work?
  1. Displaying reverse camera on a carputer?
    By coachreed in forum LCD/Display
    Last Post: 04-22-2008, 06:47 PM
  2. Anyone give me an approximate of the draw of reverse lights?
    By aoLhaTer in forum General MP3Car Discussion
    Last Post: 11-20-2005, 10:55 AM
  3. K301 Reverse cam wire
    By keanpedersen in forum LCD/Display
    Last Post: 08-15-2005, 05:53 PM
  4. reverse cam on xenarc video2
    By kuo in forum General Hardware Discussion
    Last Post: 05-29-2005, 01:33 AM
  5. reverse sonar - anyone install an aftermarket kit?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 05-16-2004, 06:58 PM
