Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Motor circuit with reverse
    Maximum Bitrate freestyler's Avatar
    Jan 2002
    Chaska, MN
    Hey all, looking for some help here.
    I want to build a circuit that when it gets power it will move a motor until it hits some sort of sensor. Then when power goes away it moves in reverse until it hits a sensor. I've been googling it but can't find too many good resources. If I can't figure this out I'd have to just use a toggle switch and stop the motor myself.
    1997 Jeep Wrangler Rugged Waves
    Ebay Stuff For Sale
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    you could do this with a few relays and some spst switches.
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Ok, I'm fairly sure its way too late for this, but heres an icredibly easy to understand paint rendering
    The red box is a latching DPDT relay. The green liney thing on the left is a SPST relay, and the blue things are your switches to stop it from moving.
    Now, I'm not entirely sure it would work, but I'm not gonna worry about that now. Maybe tomorrow morning.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    while not quite sure what you are trying to accomplish and how, but i believe i read something somewhere that you could control a stepper motor via parallel port quite easily...
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You can use a mini-SSC controller to run a servo. You can control how far it goes. If necessary, you can use a continuous rotation servo. The controller is accessible via VB and the serial port.
    What is the application of the motor?
    Want to:
    Jun 2005
    Bellevue, WA
    this circuit should work. it better both the switchs are normally closed even though the diagram doesnt look like it. M$ paint isnt really that good. And im watching blind-date right now so im kinda preoccupied.
    Jan 2002
    Chaska, MN
    well i have two different applications for it, one for moving an LCD and the other is to possibly rotate an antenna
    Ebay Stuff For Sale
    Jan 2002
    Chaska, MN
    Quote Originally Posted by markland556
    Could you explain this a little bit? Are those SPST or SPDT relays?
    Thanks.
    Ebay Stuff For Sale
    Jan 2002
    Chaska, MN
    I tried building that circuit using SPST relays, it didn't work right.
    What I need is so that when you give it power the motor spins up, then when it hits the first switch it stops.
    When you kill the power to the circuit it spins in reverse until it hits the second switch.
    Back to the drawing board I guess, I burnt up one SPST relay though
    Ebay Stuff For Sale
    Feb 2004
    PA, USA
    Did you try mine? The SPST relay should stop the current, until the Accessory power is lost. Then the reset coil would become energized, and would run until the sensor was tripped. Then the whole thing would wait until the reset was triggered (power to ACC was lost) and would run until the second sensor was triggered.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  1. Displaying reverse camera on a carputer?
    By coachreed in forum LCD/Display
    Last Post: 04-22-2008, 05:47 PM
  2. Anyone give me an approximate of the draw of reverse lights?
    By aoLhaTer in forum General MP3Car Discussion
    Last Post: 11-20-2005, 09:55 AM
  3. K301 Reverse cam wire
    By keanpedersen in forum LCD/Display
    Last Post: 08-15-2005, 04:53 PM
  4. reverse cam on xenarc video2
    By kuo in forum General Hardware Discussion
    Last Post: 05-29-2005, 12:33 AM
  5. reverse sonar - anyone install an aftermarket kit?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 05-16-2004, 05:58 PM
