Results 11 to 20 of 22
Thread: Where to buy electrical components??
  1. #11
    Jun 2005
    Phoenix, AZ
    Well, I'm confident I can build it. I just need to know exactly what parts to use; that's all. I have experiance with soldering and circuit boards, I just do not know what components to buy.
  2. #12
    Jun 2005
    Phoenix, AZ
    So, I can not figure out the rest of the part numbers to order. Can anyone lend a hand? Also, shipping from Mouser is about $5.50; half of what digikey charges. So, I should be able to get all the components for under $10, not bad.
    Scott
  3. #13
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Well, now that I looked at it, for 5A out you are definetly want regular thru-hole resistors, and something that is a little higher wattage. They shouldn't need to be more than 1w. But I'd prefer to have someone better than I look at the circuit.
    And nevermind that inductor I pointed you to. Use this one: 70-IH-3-50
    The other one would never handle the current.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  4. #14
    Jun 2005
    Phoenix, AZ
    kiltjim - Alright thanks for all your assistance.
    Can anyone else out there figure out a more detailed parts list for this project?
  5. #15
    May 2005
    http://digikey.com is good. but sometimes the selection can be overwhelmind
    http://mouser.com is another good one
    Allied Electronics and Newark are good for more electromechanical types of things.
    http://jameco.com is pretty good too. Think of it as what radio shack used to be only lager
    Some good surplus suppliers that usually have good deals are:
    http://allelectronics.com
    http://bgmicro.com
  6. #16
    FLAC evandude's Avatar
    Mar 2005
    Maine
    picking out parts from digikey is a lot easier than mouser, their organizational system is far better IMHO... however none of your components are very odd so it should be a no-brainer to pick them out...
    if you are really having that much trouble, then find an item close to what you want, and download the catalog page (available as a PDF) and then just change the page number in the address bar to browse nearby pages. that way, you see some pictures of the items as well as all similar items grouped together. all the advantages of the catalog without having one in hand with mouser, I find that it is MUCH easier to do it that way. with digikey, I usually don't have to, but occasionally it's useful.
    then do yourself a favor, and order catalogs from digikey and mouser. both of them are very good about keeping you very well-supplied with catalogs, it seems like i get a new one all the time it will save you time in the future.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  7. #17
    Jun 2005
    Phoenix, AZ
    I understand how to browse the websites. I am unsure of what components I am actually looking for 1/2 watt 1/4watt?? 5%?? I don't really know what all this stuff means. For example, I know that a need a 2.7K Ohm resistor for one part. There are hundreds of differnt types of that resistor, which one is correct? I'm trying to find what the correct components to use with the MAX 724 are.
  8. #18
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    there are 1.4 watt resistors and 1/2 watt ones, just all the spece of the resistor. the 5% just tells what its limits are.
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
  9. #19
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by markland556
    I think he's asking what the difference is between a 1/4 watt and a 1/2 watt resistor are (besdies the specs)
  10. #20
    Jun 2005
    Phoenix, AZ
    I'm just trying to figure out what the correct parts to use with the MAX724. I was hoping someone with a little more electrical background could outline what parts to use for this purpose.
  1. Drivesoft Buy or Build
    By wantone2 in forum Newbie
    Last Post: 09-23-2005, 01:30 PM
  2. Anywhere in UK to buy a carnetix?
    By mp3oplecarrier in forum Power Supplies
    Last Post: 01-06-2005, 08:29 AM
  3. Rikaline 6010 - where to buy in Greece?
    By Johnnie in forum GPS
    Last Post: 12-09-2004, 05:07 AM
  4. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
  5. Where to buy seiko L4034
    By Adam F in forum LCD/Display
    Last Post: 12-26-2001, 11:21 PM
