welcome to the foums. you should find it if you searcha bit more because i have asked the same.
you need an analogue input board, and connect that to the resistor network, you can then set diff voltages for each action.
I'vebut haven't found a useful thread regarding how to make the factory steering wheel audio controls buttons functional, when a resistor network is used. I don't want to use the IR solution, but need something that can make these different voltages into simple keystrokes. Is it doable?
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
just looked at your thread (Corsa ....), but swix solution is IR. The gamepad solution is not possible because these buttons aren't seperate. It is just 2 wires, when buttons are pushed:
Vol - 54 Ohm
Vol + 147 Ohm
Mode 1036 Ohm
Mute 2007 Ohm
Preset 562 Ohm
^ 300 Ohm
No buttons pushed 5kohm
I'm sorry if I didn't understand you correctly.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]Don't mess with Texas.
It's not nice to pick on retards!
