Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: xm cable shorting powersupply
  1. #11
    was Boston -> now Canada!
    I too made a cable following the instructions on this sight and have the same problem.
    If the PC is powered up and I go to plug in the serial cable the PC will reboot. It reboots just fine. I don't think it is working though because it doesn't find a serial mouse of any device connected to the serial port.
    I double and triple checked the wiring and all seems fine. Don't know why it reboots like that.
    Chuck
  2. #12
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    i've had that happen before, sometimes the inital power draw of the unit is high, will cause my opus 150 to restart, I just make sure not to plug the XMD in while the psu is running.
    肚子笑痛了
    S60 Install
  3. #13
    Is Pin 3 and Pin 8 on the mini din connector supposed to be connected when the cable is plugged in?
    When the cable is totally unplugged there is no continuity through these pins. When I connected both the power cord and the serial connector in the MB then the two pins have continuity. The PC is off when doing this.
    ****It's working. It just doesn't like to be plugged in while the PC is running.
    Chuck
  1. Got My XM, But Whats with my Cable?
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 01-08-2008, 05:55 PM
  2. Problems with XM Direct Cable
    By HummDinger in forum General Hardware Discussion
    Last Post: 07-08-2005, 09:16 AM
  3. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 03:45 PM
  4. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 01:47 PM
