Results 1 to 10 of 13
Thread: xm cable shorting powersupply
    Constant Bitrate mikevsgeek's Avatar
    Jul 2004
    Auburn Maine
    I recently made a cable for my xmdirect.. it plugs in the serial port fine, and it plugs into the power connector fine.. but once I plug the cable into my XMD, the powersupply completely shuts down for like 30 seconds... I used a multimeter to match up the wires to the pins, and then I even double checked them after making my cable and they all seem to right...
    what else could I possibly be checking?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you must have something shorted, thats the only way it will cause the power supply to shutdown. Are you sure you wired it the correct way? Because I know I always get confused when i'm looking at the pinouts I always seem to get them backwards
    Did you use a mac printer cable or did you buy the din connector?
    肚子笑痛了
    S60 Install
    Jul 2004
    Auburn Maine
    Quote Originally Posted by jcdillin
    I went out and bought a new mac printer cable... I checked the pinouts a couple of times.. perhaps I will again... my cable did have 10 wires including the sheilding which I thought was weird...
    May 2003
    Miami, FL
    you have 10 wires wired up, or there was 10 wires inside the cable?
    肚子笑痛了
    S60 Install
    Jul 2004
    Auburn Maine
    there are 9 wires inside the cable, plus the sheilding... but there are only 8pins on the minidin connector.. weird huh? I only had 6 wires wired up though
    May 2003
    Miami, FL
    i've found that in some of those cables that they have one wire that is tied to the shield
    肚子笑痛了
    S60 Install
    What power supply do you have? I had the same issue.
    Jul 2004
    Auburn Maine
    Quote Originally Posted by t00h0t
    I had the issue one two different powersupplies.. However I do see why the problem would relate to the powersuppply when they are both in good working condition...?
    Quote Originally Posted by mikevsgeek
    I have a Carnetix P1900 and noticed that if I plug in the XM direct unit while the computer is on, the power supply shuts off. But I can turn it back on once its plugged in. However it draws too much current and the PS shuts down to protect itself. Just curious if you have the same PS. I believe these XM direct units are drawing a considerable amount of power.
    Jul 2004
    Auburn Maine
    I tried only plugging the power cable in (and not the serial cable into the computer) and the xm radio started smoking... burnt up a resister on the inside I dont know what the problem is.. I checked and double checked the pinouts and compared to the schematics serveral times... something is ****ed
  1. Got My XM, But Whats with my Cable?
    By nFiniteTuning in forum General Hardware Discussion
    Last Post: 01-08-2008, 06:55 PM
  2. Problems with XM Direct Cable
    By HummDinger in forum General Hardware Discussion
    Last Post: 07-08-2005, 10:16 AM
  3. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 04:45 PM
  4. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
