1st Problem:
Standard security mode:
In normal mode, press I for 0.5”. The system will be armed and the doors will be locked with one siren beep and one light flash. The starter kill stands by and the LED* begins flashing. Siren beeping thrice means any door is not properly closed. You shall close the door again. Otherwise, the system will alarm for 30”.
Now when I press the “I” on my pager all door will be locked, then it gives me the indication that there’s a door still open? I check all doors but they are perfectly closed!
I checked all the fuses, all the doors sensor or switch all seem to be fine.
