Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 94
Thread: Electric Window Tint
  1. #51
    Constant Bitrate S2K12's Avatar
    May 2006
    Perth, Western Australia.
    i wonder if the system can be modded, it works with an electric current right? maybe add on something to vary the current that goes into it? would that work?
  2. #52
    Oct 2006
    Quote Originally Posted by Got_Mach View Post
    The "electric tint" on the market today has one major drawback. It is only designed to go from clear to opaque. The original poster's idea of using it as a security device when parked is the only feasable one, based on current technology. Once activated, you can no longer see through it.
    <Enables spellcheck>
  3. #53
    May 2006
    yeah but it tints by putting a current through the panel right? so variying the current...
  4. #54
    Oct 2006
    Looks like I'm having crow for dinner. This is actually very new technology. Check out these articles:
    http://www.refr-spd.com/press.asp?re...s%20Operations
    http://www.ltismartglass.com/evtp.htm
  5. #55
    Oct 2004
    NY
    I just sent ltismartglass an inquiry from my bussiness.... this would be so cool, even if it was a bit expensive..... we'll see
  6. #56
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    Technical Specifications of SPD Variable Tint Glass
    Description Specifications of
    SPD Variable tint glass
    Solar Light Transmittance Min.<1%, Max. 70%
    Size Max. 3ft.11in. X 8ft.2in
    Max. 1,200mm x 2,500mm
    Response Rise :<0.5second., Decay :<1.0second
    Power Supply 80~220 VAC, 50~60 Hz
    Power Consumption <5 watt per 10sq. ft. of SPD Glass
    <5 watt per 1sq. meter of SPD Glass
    Switching Durability Over 10E+06 times
    Workable Temperature -30~+90 degree C
    NOTE : the power supply!
  7. #57
    Nov 2006
    Quote Originally Posted by Pb2theMax View Post
    I would love to have a license plate cover made of Smart Glass, so if I "accidently" have to run a red light, I could flip the switch and the red-light cameras would not be able to see my license plate or send me a ticket.
    I'm going to contact some of these Smart Glass companies to see if this can be done, and how much it would cost.
    Here You Go
    sold for motorcycles ,not sure if they have a car version
    http://www.flashalert.com/eclipse.htm
    goes for about $175 us and goes from clear to black
  8. #58
    May 2006
    no car one available, well if there is i havent found it yet, but if u do ur windows with it the licence plates shouldnt be to hard, should it?
  9. #59
    May 2006
    i had a thought. i wonder how hard it would be to use it to tint ur lights so that whenever they go on the tint goes off (then u could have it darker than a light coating of nightshades etc when ur not using it and clear when u are)?
    like this:
  10. #60
    Nov 2006
    does anybody know the price for this film and where to buy it?
  1. Onscreen keyboard
    By gti in forum Map Monkey
    Last Post: 06-14-2008, 11:00 PM
  2. Alpine City Cruise
    By Hell-Stopper in forum RR Skins
    Last Post: 02-22-2007, 11:05 PM
  3. iGuidance 2.x auto-run shortcut
    By ziggyrama in forum GPS
    Last Post: 08-13-2005, 07:05 PM
  4. Does window tint really make a difference?
    By Ascension in forum LCD/Display
    Last Post: 07-26-2005, 08:03 AM
  5. window tint on lcd?
    By cash_Money in forum General Hardware Discussion
    Last Post: 12-13-2004, 10:48 PM
