Results 1 to 10 of 10
Thread: Car Window Switch Replacement
    Nov 2003
    Florida
    Im trying to make a screen come up in the back of my car, and i hooked it up to a power window motor, but i've been looking for a power window switch to put on my center console to control it, but all the single power window switches i find are like 30 or more dollars, and on ebay, there mainly all bunched together, no single switches.
    So I'm looking for a switch, that I can use instead of an actual window switch. But all I know is that it's a rocker type switch, but all of those, just switch from one side to the other, they don't pop back up like car window switches.
    Is there such a switch replacement, and does anyone know where I can find one?
    -=Chevy CarPC=-
    ETA: When i get more time
    -Custom Fiberglass Case
    -Epia M-10000 Nehemiah 1Ghz
    -Sony CDRW-DVD Drive
    -Seagate 120mb Hardrive
    -Opus 90w Power Supply
    -Lilliput 7" LCD
    Jun 2004
    Central California
    Try mouser.com. They've got varieties of switches.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    Jul 2005
    Sweden
    Don't know what it's actually called in english but in Sweden it's called unistabil or monostabil.
    Would guess it would translate into unistable/monostable. It comes in different versions
    (on)-off / (on)-off-(on) / (off)-on / (off)-on-(off). Where the one in paranthesis (sp?)
    is when the button is pushed, which then reverts back to its original position..
    If you're using a power window motor, then you problably would want the possibility of
    moving the screen down after hoisting it up. Thus a (on)-off-(on) switch would be perfect.
    Cheers
    /p
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You have to use a double pole double through with center OFF, Like those.
    And here is the Wireing.
    Nov 2003
    Florida
    MGD, do those revert back to the center, like paran0id mentioned?
    -=Chevy CarPC=-
    -Lilliput 7" LCD
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    is paranoid talking about a momentary switch?
    PC Components:
    My work log
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you're looking for momentary switches. but why would you want to hold and press a button while the monitor rises?
    why dont you consider using a togle switch with a micro switch that will cut power when the monitor when it reaches its predetermined height? and then another switch at the bottom the monitors travel.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Aug 2005
    junkyard and start ripping apart car doors
    Nov 2003
    Florida
    Quote Originally Posted by scott_fx
    I thought about that, and that's why I went with the window switch. I also got one of those power window modules, that allows for one-touch open and closing of windows. So i just push down once and it goes down, then i push up once, and it goes back up. but I still need a replacement for window switches because there rediculously expensive, and there has to be a normal switch that does that same thing.
    -=Chevy CarPC=-
    -Lilliput 7" LCD
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. That new car smell...
    By PatO in forum Off Topic
    Last Post: 04-01-2005, 03:29 AM
  3. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 10:25 PM
  4. FP Feature Requests
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-15-2004, 02:19 PM
  5. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
