Results 1 to 3 of 3
Thread: Racers Lap Timer
    Newbie eastcoastbumps's Avatar
    Mar 2005
    Central MA
    Racers Lap Timer
    I need to set up a lap timer in my car. I'd like to run it through my carPC, rather than buying something like the Longacre lap timer. http://www.longacreracing.com/catalo...d=271&catid=10 I'd have to set up something like this http://www.longacreracing.com/catalo...d=861&catid=10 with an auto trigger, rather than a manual one. Anyone have any ideas on even where to start?
    Thanks,
    Pete
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    in R/C car racing there are transponders that go in the car and they have the main unit that all the cars run under hooked up to a laptop. I dont know really what kinda of setup they have but in your case you would mount the transponder outside over where the lap starts/stops and have the computer hooked up to the reciever.
    96' Mercedes Benz C36 -Matte Black-
    Status..::... {##------}25%~~ back to planning
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    As far as an automatic trigger, most systems have an infra-red transmitter on the side of the track or a loop embedded in the track. I tried it using a remote control kit (as in a car alarm style one) but it wasn't real accurate. Probably the easiest is the infra-red transmitter. You can make one out of a dolphin torch and some IR leds. There should be quite a bit of info on the net about making IR floodlights, which is the same thing.
    You then need a receiver in the car and then have it trigger your data pins in your serial or parallel port. Then all you need is to count the time between the pulses. You could probably write a crude app in VB to do this for you.
    Note: Some track officials can get quite funny about timing yourself at trackdays. Been there and done that.
    Hope this helps
  1. Fan Timer
    By UM_Fan in forum General Hardware Discussion
    Last Post: 03-26-2005, 07:58 PM
  2. sleep timer for lcd projector
    By ŠuTcH in forum Off Topic
    Last Post: 11-23-2004, 08:00 PM
  3. help to design a timer circuit
    By CdRsKuLL in forum Car Audio
    Last Post: 10-23-2004, 06:07 PM
  4. LAP TOP HD 2.5"
    By lepinos in forum General Hardware Discussion
    Last Post: 02-21-2004, 04:07 AM
  5. why not simply use a lap top?
    By asif in forum General MP3Car Discussion
    Last Post: 06-29-2000, 07:30 PM
