Results 1 to 10 of 15
Thread: timed relay?
    FLAC djmickyg's Avatar
    Feb 2004
    timed relay?
    im after a relay that when triggered with a quick pulse will stay connected for about 2 mins then shut off..
    something like a turbo timer but with out the price?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by djmickyg
    Someone posted a link to those relays once. They were pretty damn expensive!
    Feb 2004
    yeah ive had a search around here and only found them..
    there is gota be an easy way to build one..
    i was gona search the net some more but i figured someone here might know
    there is a cheap turbo timber on ebay au for au$30 which would do what i want..
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    If you're into DIY projects and know how to use a soldering iron, use the 555 IC chip.
    Run a Google search on Time Delay 555 and see the examples. To make it do the work for you, use a proper relay on the other end (insead of LEDs as they appear in many examples). You will be able to set the time correctly (up to 10 mins) by getting the correct amount of resistance and capacity (you'll see those in the various examples).
    Good luck.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    I bought a DEI 528T pulse timer relay on ebay for $25. Retail is $49. There's some on ebay right now for less than $20 shipped, can't beat that IMO.
    They work great too. But the details on those auctions are incorrect, it's max 15 amps. Any more and you need to use it with a seperate relay.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
    Jan 2004
    Jersey/NY
    http://www.hometech.com/brains/timers.html
    scroll down to the ELK-960
    I use that right now, after ~60 seconds (which you can change from a few seconds up to 60 minutes, I just happen to use 60 seconds), it cuts off the relay so when I hit the switch to shut off my opus, if a software lockup occurs, I can walk away and not worry about my battery being drained (which happened to me before I bought this timer).
    The timer is VERY programmable, you can set it to start counting when you switch the input high, switch it low, cut off the input, all that jazz. I think it can repeat, a bunch of other stuff.
    I forget where I bought it, was too long ago. The link I gave above is around $21 (before s/h), and that's right around what I paid. May be able to find it for cheaper, I dunno.
    Nice product too. Relay can't handle a LOT of current though. I intentionally just bought a 30 AMP relay as well for a couple of bucks. That way this fancy relay just controls the 30 AMP relay. Has worked beautifully for me thus far.
    Good luck
    Jan 2004
    Jersey/NY
    http://www.elkproducts.com/products/elk-960.htm
    there's the product page direct from the manufacturer
    Oct 2004
    NY
    you can look into the pac tr-7.. it has a lot of features & can do what you are looking for too
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    This is what I got from a friend of mine when ask him for a timer relay for a little project that I have in mind
    It work for 0-15 min.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Registered User
    May 2003
    He said >>>
    People dont read anymore
  1. Lock-start-puter circuit.
    By KyleYankan in forum Hardware Development
    Last Post: 07-17-2005, 12:05 PM
  2. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 07:55 PM
  3. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 12:39 PM
  4. timed relay???
    By Slitha in forum Power Supplies
    Last Post: 09-02-2004, 06:51 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 04:50 AM
