How about taking another approach to what you are trying to do. Remember there are several things that happen when you start your car every morning. Several things give a momentary pulse to begin certain sequences. In your case since you don't have extensive knowledge with electronics just tie a relay in to your starter wire. The starter on your car is simply activated with a momentary switch. This will fix your problem but also install a toggle switch to the relay so you can turn off that function when you don't want it to work. (i.e. when you send your car in for service and they are starting your car to test for problems.)
Hope this helps
LinkBack URL
About LinkBacks
