Results 1 to 9 of 9
Thread: PCI bus
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    PCI bus
    Is it possible to wire two PCI cards in parallell? Anyone know how a dual riser card is connected to the PCI bus?
    Raw Wave tj!2k4's Avatar
    Oct 2004
    multi-slot riser cards have a connector for each pci slot.
    Jan 2004
    Stockholm, Sweden
    Yes I know, but are they connected in parallell pin by pin?
    Oct 2004
    Jan 2004
    Stockholm, Sweden
    Didn't really find what I needed. I want to know how the two slots are connected electrically.
    Oct 2004
    good luck.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by weekendowel
    Most signals are parallel. Some have unique pins per slot (eg, IRQ).
    Some bioses have IRQ chaining/sharing support so that a single IRQ can be used for multiple slots. This is motherboard specific.
    Jan 2004
    Stockholm, Sweden
    Ok, so this means there could be a difference between motherboards. Maybe I can find some info on VIA web site.
    Jun 2005
    If you look at the riser cards that add slots (not just a single slot going horizontal) you'll notice that there's a surface mount chip on the board. Without going into too much detail, some of the PCI signals are slot specific. Meaning, the motherboard associates certain controls lines to specific PCI slots. Each slot is not aware of these other sets of control lines and merely waits for the PCI arbiter chip from the motherboard to allow it to transfer data.
    That extra chip on the riser card is a bridge chip that functions as a "pass-through" PCI device and handles all of these control signal issues locally.
    So, in other words, you can't just "daisy-chain" multiple cards together from one PCI slot. Not all of the signals will be present... not to mention you would have a hell of a headache dealing with trace length issues, clock delays, impedance mismatches, and more.
    The easiest thing is to just buy the riser card and enjoy!
  1. FS on eBay: selection of PCI and AGP risers
    By lemming in forum Classified Archive
    Last Post: 04-10-2005, 07:58 AM
  2. pcmcia pci or pci card?
    By fuctup in forum Wireless Communications
    Last Post: 11-14-2004, 02:49 PM
  3. Jeep PCI Bus Hack
    By Laidback in forum Car Audio
    Last Post: 09-30-2004, 03:10 PM
  4. Via Epia M PCI Bus Speed?
    By Nico3k in forum General Hardware Discussion
    Last Post: 09-23-2004, 06:05 PM
  5. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 07:56 PM
