Results 1 to 6 of 6
Thread: Can I pull out 200mA from serial port of Epia 10000?
    Variable Bitrate slimmegane's Avatar
    Feb 2005
    Italy/Lecce
    Can I pull out a 200mA current from serial port of Epia 10000?
    I want to power the Axiom OEM GPS module direct from Serial Port.
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    I doubt you can get that much current from any serial port, regardless of MB. The quick search I did turned up around 10mA as the max for most boards. Why don't you just draw power directly from the PSU?
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    You could pull it from the PS2 or USB port. I have my serial GPS running off of the PS2 port. Run the connection into a custom made serial connection, and then out by a really long headphone cable I had broken. Its been working for a really long time too.
    (And who uses PS2, seriously? )
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Feb 2005
    Italy/Lecce
    Thanks, now I use the PSU +5v, my question is only to make a unique cable for data Rx/Tx and Power supply.
    Thanks.
    FLAC Gutter's Avatar
    Dec 1999
    Casina, Italy
    Quote Originally Posted by kiltjim
    *Feebly raises hand*
    Feb 2004
    PA, USA
    @Slimmegane:
    You shouldn't need both a Rx and Tx cable. You are only going to be recieving data from the GPS aren't you? Or does it have some kind of programming feature to it? And where are you going to be putting it? I have my GPS tucked under the dash, and the computer in the trunk. This means I have something like a 6-7 meter cable running the length of the car. I just used a shielded headphone cable. One end has a DB-9 connection on it, with a short PS2 cable hanging out of it. You could just put a power connector on instead of the PS2 connection.
    @Gutter:
    Hey, I wasn't talking to you! Get back in your cage!
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
  1. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
  2. Epia 10000 memory
    By Vagabond in forum Newbie
    Last Post: 09-02-2005, 12:21 PM
  3. VIA EPIA MII 10000 vs. M 10000
    By imprezive one in forum General Hardware Discussion
    Last Post: 03-02-2004, 10:17 PM
  4. serial o lpt port adaptor
    By pcman in forum General Hardware Discussion
    Last Post: 08-24-2000, 06:50 AM
  5. 1 serial port, 2 devices
    By Meatballman in forum General Hardware Discussion
    Last Post: 04-16-2000, 11:50 PM
