Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: dome light dimmer (with delay)
  1. #11
    Newbie kronos's Avatar
    Oct 2004
    Quote Originally Posted by PatO
    Kronos - how many bulbs are you lighting up? I have 4 lamps on that circuit (2 domes & 2 floor lamps) and was wondering if the transistor would require a heatsink. (not that big of a deal, but since Rat Shack is closed right now, all I can do is dream...)
    Thanks for circuit!!!
    just one bulb which is 15W or so. for your 4 you may need a heatsink. a pretty big one
    BTW - what software did you use to create the diagram? I see diagrams like that all over the place...
    would you believe it's good ol' ms paint?
    Why drink and drive when you can smoke and fly ?
  2. #12
    Raw Wave lostreception's Avatar
    NY
    pat o change your incadensants out for leds and then use the circuit as is that would probably work
    my van has 3 floors and 2 overheads i might do that
    BTW MSpaint!!!! DAYUMMMMMM that was a few hrs worth of work
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  3. #13
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    LED's... Hadn't thought of that. Thanks!
    MS Paint? Are you on drugs?
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  4. #14
    May 2004
    NJ
    MS Paint! Are you Monk? Good job though.
  5. #15
    Low Bitrate widower's Avatar
    Jun 2005
    Quote Originally Posted by kronos
    You could also change the 2n3055 from a TO220 package to a TO3 package. It can handle larger currents without a heat sink. Better yet, the 3055 has a large on resistance, a FET would be able to handle a much bigger load without heating up because of the much lower on resistance.
  6. #16
    Oct 2004
    I don't do drugs, but since you're such a nice and courteous guy why don't you redesign the scheme in a more evolved graphics package instead of throwing offensive remarks. This kinda behaviour will make me think at least twice before I will share any of my other projects. As they say no good deed goes unpunished.
    FWIW I already had the main components in a png so it was a simple matter of copy & paste and some rearranging so no big deal.
    Quote Originally Posted by widower
    the 2N3055 IS a TO3 package, the MJE3055 which I used is a TO220. of course the 2N3055 is way better, but I was a little constrained on space: it had to go in the lamp assembly which is kinda tight and the TO3 package is almost as big as the whole circuit so for me the MJE3055 was the choice. anyway, to each his own... so if you have the space go for the 2N3055 by all means.
  7. #17
    Aug 2005
    my roomate at school and i are attempting to build this and have hit some issues. Im not a EE but he is, so he understands the electrical diagrams, he says there are a couple components that dont appear on the diagram, the resistor to the left of the pot, and the beige component in front of it. we built the circuit to spec based on the diagram as far as we could tell on a protoboard and hooked it up to a 12v supply and everything but couldnt get it to work. any troubleshooting suggestions?
  8. #18
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    I'm sorry if that remark was taken negatively. I meant it in a sarcastic tone to indicate that I admire your dedication to creating accurate and descriptive diagrams. Please don't think that I am bashing you in any way, shape, or form! I truly appreciate this diagram and will implement it as soon as time permits!
  9. #19
    Oct 2004
    Quote Originally Posted by ethlar
    I have added two small resistors; 470ohm in series with SR1 and 1k2 in series with SR2 in order to have a small impedance when the pot's is zero so as the capacitors discharge or charge through some impedance instead of straight through wire (they're limiting the current a bit); they are not critical and as long as you don't set the pots to zero you don't have to worry. Indeed I added them after the scheme was done and I forgot to draw them in... my bad, but it should work without them given that they are a kind of... let's say added protection. check your connections on the protoboard, because my prototype was done without the small resistors as well and it worked from the moment I powered it up. what exactly is not working? does the led light when you power up the circuit? also take a multimeter and check voltage at:
    pin 3: it should be aprox half the voltage of the source
    pin 2: after power up it should raise from zero to aprox the voltage of pin 3 in somewhat less than the time constant for the SR1-C1 (time constant[seconds] = R [ohms] x C [farads])
    tell me more details cause I'm troubleshooting blind here.
    ... ok, edited the first post with the updated scheme (the two resistors added)
    I'm sorry if that remark was taken negatively...
    ok, no offense taken. I was tired and just had one of those days and everything upset me.
  10. #20
    Aug 2005
    thanks for the update. we were able to get the led to light but couldnt get the dome light, which i had removed from the car, to light up. we will get back into the electronics lab and check the voltages you listed. i will try to get more details after we get back in.
  1. Opinions and suggestions on my dome light dimmer project
    By LiquidKernel in forum General Hardware Discussion
    Last Post: 06-19-2005, 03:49 PM
  2. Dome Light Fade-in and Fade-Out Successful!
    Last Post: 06-12-2005, 10:04 PM
  3. How many does it take
    By veedubya in forum Off Topic
    Last Post: 06-03-2005, 01:15 PM
  4. BU-303 Dim Light????
    By KingsDude in forum GPS
    Last Post: 02-12-2005, 10:23 PM
  5. How Many Does It Take...
    By mp3z24 in forum Off Topic
    Last Post: 09-19-2004, 11:54 PM
