Results 1 to 8 of 8
Thread: Picaxe based Aircon digitiser
    Aug 2004
    Bundaberg QLD AU
    My car, a toyota corolla 97 model, has manual cable operated aircon co trols except the fan speed which is a switch.
    Now I would like to convert the other three to electronic too.
    What I'm thinking of doing is to build a circuit that has a picaxe probably a 18x if it has enough ports, with 3 servos to digitise the cable operated ones. now the hardest part is going to be the inputs to control these servos. the temp is a variable thing so it needs a knob/slide with no positions. the vent direction could be converted to a push switch for open close though mine has 3 positions open 1/2 closed, so i'm not sure if i'd worry about the 1/2 position. and finally the vent direction, eg face, feet, etc
    now i'm not sure what i'll use for user input, but i was thinking of using a mono nokia lcd with backlight for displaying fan speed, temp, etc with icons would be great.
    is this all doable with a picaxe? has anyone done this before to save me some work?
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Quote Originally Posted by birdie
    I have use the small PICAXE 08M in my shutdown controller and it work fine
    The PICAXE is wery easy to get work,
    I wish you good lock witch you project
    I work on 3 other projet where i use a PICAXE processer
    If you to know some thing about PICAXE search on GOOGLE and you will find lot of stof
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    Oct 2002
    does the 'axe have enough memory to hold the code to do all that?
    May 2004
    Denmark
    Quote Originally Posted by davesaudio2
    Yes, the X version have space for 600 basic programs line
    and it can control EEprom to store data in
    Try to look at it ..
    Ditail at 4u2n.dk
    Here
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Yeah PICAXE is good for small things like this, fast and easy to develop and they're quite robust. They also don't need a special programmer.
    The only problem I can see is that you'll need to interface with that LCD somehow.. Picaxes can talk to HD44780 based LCDs quite easily, but what controller does that Nokia use?
    May 2004
    Denmark
    Quote Originally Posted by starfox
    If you search on the internet then you lot of place where you can use the picaxe
    You control the picaxe nearly same way as normal pic
    And a very good thing is if you start witch one of the small once and the project grow you change the picaxe size and the pin to the new one, the en run
    Ditail at 4u2n.dk
    Here
    Oct 2002
    help me better understand, when I see a guy who can etch boards I wonder why he prefers the axe over a pic?
    a few resistors makes a jdm programmer, free HLLs exist, lots of code available ...
    curious Dave
    May 2004
    Denmark
    Cool
    curious Dave
    Fart to make program without to know some thing about asm.
    Make the program in block diagram press 1 bottom to make it to basic on press more and you download it to the PICAXE
    try to check it out on this link
    http://www.rev-ed.co.uk/picaxe/
    Ditail at 4u2n.dk
    Here
  1. Hardware based players (Not PC based)
    By andrewc in forum Newbie
    Last Post: 05-31-2005, 03:36 PM
  2. Replies: 2
    Last Post: 02-05-2005, 12:48 PM
  3. Open Source Visual C++ based players?
    By millec in forum Software & Software Development
    Last Post: 11-24-2004, 01:15 PM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
  5. MercuryX: New Album Based Media Interface
    By qjones in forum Software & Software Development
    Last Post: 05-24-2003, 03:04 AM
