Results 1 to 2 of 2
Thread: Autostart / Autoshutdown circiut
    Nov 2005
    I'm working with a CarPC and I want to install a circiut who
    enables a relay so the computer can start.
    And I also want the circiut to shutdown my computer "soft" by "pressing the power button once" so that windows shutsdown. One minute later the relay should close the "main power" so that if not the computer has shutdown it lost its power.
    Any idea how to do this?
    /Sorry for my bad english!
    FLAC evandude's Avatar
    Mar 2005
    it's called a shutdown controller, search the forum and you'll find hundreds of pages of info. it can be done lots of ways, depending on how much you want to spend on it, whether you want to build it from scratch, and how fancy you want it to be. for instance, some people do it with just relays and a few discrete components, other people use microcontrollers and such, like my design
    also, you should definitely check out the thread FAQ: Do-It-Yourself Startup/Shutdown Controllers
    and while you're at it, check out the rest of the stuff in the FAQ forum, there's plenty of good info there.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
  1. autostart program?
    By cyberlancer in forum Operating System Optimization
    Last Post: 05-12-2005, 08:19 AM
  2. Replies: 0
    Last Post: 08-06-2004, 05:27 AM
  3. Streets and Trips 2004 - Autostart
    By Insight in forum GPS
    Last Post: 06-10-2004, 09:36 AM
  4. Replies: 6
    Last Post: 11-06-2003, 03:00 PM
  5. LCD Plugin Autostart
    By mprover in forum General Hardware Discussion
    Last Post: 08-21-1999, 06:46 PM
