Results 1 to 4 of 4
Thread: XM Direct question
    (6) is offline
    Newbie (6)'s Avatar
    Oct 2004
    Question XM Direct question
    Inside the xm direct housing the board isattached to the side of the housing. Is this neccesary to be touching the housing wall?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    You mean the voltage regulator that is bolted to the inside? If your going to run the XMD without a case I would at least put a small heatsink on that reg i've had mine get pretty hot at times
    肚子笑痛了
    S60 Install
    (6) is offline
    Newbie (6)'s Avatar
    Oct 2004
    Question
    Quote Originally Posted by jcdillin
    What kind of heatsink do you recommend i use so this wont over heat not using the case?
    May 2003
    Miami, FL
    something like this would work fine
    http://www.electronics123.com/s.nl/s...t.A/id.1078/.f
    肚子笑痛了
    S60 Install
  1. Problems with XM Direct Cable
    By HummDinger in forum General Hardware Discussion
    Last Post: 07-08-2005, 10:16 AM
  2. Xm Direct Cable Ready For Shipping!!!
    By HybridMike in forum General Hardware Discussion
    Last Post: 07-06-2005, 10:58 AM
  3. XM Direct timeout? problem
    By eleventh in forum Hardware Development
    Last Post: 01-23-2005, 08:38 PM
  4. XM Direct optical out to Catalina question
    By Lord_Pall in forum General Hardware Discussion
    Last Post: 01-16-2005, 07:16 PM
  5. XM Direct Epia line in
    By bjm2020 in forum General Hardware Discussion
    Last Post: 12-27-2004, 11:03 PM
