BJ,
I do get a little static in some areas. Would Quad shielded RG6 soldered straight onto the USB unit from the antenna, improve the reception at all over the current 4metres of RG59U airspaced cable which I have connected via the stock motorola plug?
Is it true that the aluminium braid shield is difficult to solder onto the board?
Should I solder/connect directly onto the antenna or leave the motorola plug in place? (I assume this plug+cable has a different impedance than 75Ohm)
LinkBack URL
About LinkBacks
. Either it crashes or that DLL mutes all
