Page 18 of 42 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 418
Thread: USB FM RDS Solution with sofware
  1. #171
    Dec 2005
    Sydney
    Quote Originally Posted by crispyrabbi View Post
    Is it just me that gets no sound after changing frequency in radiator. I am using radiator and the DLL that you can find in a link to somewhere in this post. It works fine until you try to change the frequency. Then you get no sound and radiator freezes when you try to end the program. If I kill the radiator.ini file I can use the program again.
    The silabs device has good reception in stationary use. Havnt tried it in the car yet.
    I havent had the problem, but i think someone posted previously said something about usb devices, unplugging something, not really sure??
    i've noticed that there are 2 different dll'd for radiator on here. I've got this one and it works ok.
    http://www.alibri.it/RRMobile/Silab%20USB%20Radio.htm
    let me know how you go with that
  2. #172
    Jan 2006
    Quote Originally Posted by SmoL View Post
    they are called braemac, i ordered from their syd office aswell. Give em a call
    Yeah, that's the one. Will give them a call. Thanks.
  3. #173
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by royandrews View Post
    Ask for Lisa Diaz. She was the one that helped me out.
    I installed my carpc into my pet Kangaroo, mate.
  4. #174
    Low Bitrate crispyrabbi's Avatar
    Nov 2006
    Sweden
    I have tried with two different dll:s with no success. Are you supposed to just copy the dll in your plugin dir or all of the files in silabtest?
    It still locks up after you have changed the frequency. Works fine with the silabs original program.
    AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
  5. #175
    Nov 2006
    Sweden
    I thought maybe the fault is in my carpc setup so I tried to launch radiator in a stationary computer but it wouldnt even start. I get som Eaccess error so I cant even start radiator.
    The silabs original program works fine. I figure radiator must be some extremely buggy program. Or am I missing some crucial install? Some codecs that have to be installed or something else?
    I thought the only installs where the radiator package and the dll file.
    Are there any alternatives to radiator if I want to use silab in RR?
  6. #176
    Sep 2006
    Cornwall, England
    USB radio frequency error!!!
    Been playing around with the USB radio for a bit and have noticed a small problem with my radio...
    In my house 'Radio 1' is at 99.30MHz, a local station 'Pirate FM' is at 102.80MHz. Any radio I use, auto tunes to these frequencies. The USB radio is .10 MHz out, which is pretty anoying. This is the same with every radio station it tries and tunes too.
    Anyone else had this with there radios?
  7. #177
    Newbie umpculi's Avatar
    Jun 2006
    Smile
    Did u switch radiator settings to use external dll? check config on radiator program folder if you can see external driver=usbradio.dll. Gud luck!
  8. #178
    Dec 2005
    Sydney
    Quote Originally Posted by portreathbeach View Post
    have you tried not using the search functionality and tried manually incrementing by .10mhz??
    you could also set it up as a preset.....
  9. #179
    Newbie SUNAJ's Avatar
    May 2006
    Denmark
    Quote Originally Posted by Bj View Post
    Mouser still sells them - I got mine the other day.
    These little tuners are fantastic! It performs 1 billion times better than any of the previous usb radios I have used. I attached an external antenna (75 ohm) to a standard house type splitter between my tv tuner and the silabs. I used to use the magic box pro for FM, but the performance (even though it was the best I had found at that point) is absolutely no match to the quality and signal strength of this tiny little radio! And to make things even better it supports RDS.
    Here is the antenna mod I did...
    Fitted in car
    Here it is running a full 75 ohm system and splitter to both the silabs and the DVBT tuner part of the magic box pro
    The only issue I have found is that the RDS info is all jumbled up, or it doesn't refresh at the rate it comes in at. I downloaded the demo from this thread, and all I get it chopped up sentences, it seems that the data coming in is scrolling, but the app can't refresh at the same rate as the scrolling....
    Any ideas on this?
    Other than that I have got this functioning in my car, all but the rds..
    I'm using the vb6 example from a thread I can't find now, but thanks to whoever it was
    Where dit you get the Silabs USB tester program? cannot finde it
  10. #180
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    how's the reception while moving?
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Not enough power to USB devices >> Possible Solution?
    By Tuckie in forum General Hardware Discussion
    Last Post: 11-16-2005, 12:24 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. FS: USB TV / FM Tuner, haupauge usbtv
    By e36mp3 in forum Classified Archive
    Last Post: 11-18-2004, 11:03 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 02:56 PM
