Page 21 of 42 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 418
Thread: USB FM RDS Solution with sofware
  1. #201
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by geeky_hawkes View Post
    I second what grayvader has said above really. IM using it connected to my car aerial and the quality is fine, im using it in streetdeck and the integration isnt too bad either! (Especially for 1 £10 card!)
    ehh?
    Whats £10, and what card? its a dongle and its £27 !
    Lez, more widely known as flez1966
  2. #202
    Dec 2005
    Sydney
    Fantastic News!
  3. #203
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by SmoL View Post
    Fantastic News!
    what is ?
  4. #204
    Jun 2006
    Card or dongle, i mean its a usb device (not splitting hairs!) And i got it for £10 so happy with that! Even for £27 its worth it though!
  5. #205
    Dec 2005
    Sydney
    the guy with good reception, thats what
  6. #206
    Low Bitrate jjnit's Avatar
    Feb 2007
    CRAP!
    Well I went out this weekend to do a lot of stuff on my install, part of which was to connect this to the factory aerial. Here's a pic of my soldering job which I thought was pretty good honestly.
    I thought it was all good but sometime about an hour after I did it it stopped working, must be a cold joint or something.
    Soo - I;'ve got to go back and fix it next weekend (I'm assuming it's a bad solder and that I didn't ruin the board) before I can test results.
    I did sheild left and center right - that's correct isn't it? Sort of odd since the PCB doesn't have a trace to the pad that I soldered the sheild to?!?!
    Bj/Iceman - any advice?
    Thanks!
  7. #207
    Sep 2006
    Without reading all sites...
    ...is this radio working with hibernate?
  8. #208
    Feb 2007
    Quote Originally Posted by dudeness View Post
    Yep. I've had an occasional issue(read: like twice in the last 3 weeks) but simply tune to another station and back and you're golden. Doesn't lock up or anything or need a reset.
  9. #209
    Sep 2006
    Cool, sounds good. The ADS Tech radio is constructed in the same way, so it also supports hibernate? (Silabs Programm works with ADS Tech Radio).
    I cant find a shop which sells the silabs in germany (without 15$ shipping) so i hope the ads tech work also.
  10. #210
    Feb 2007
    Don't know enough about the ADS to say for sure but I don't imagine it will have any issues. You can always use software to disable the USB device causing issues before hibernating - I forget the name but it's pretty common on this forum...
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Not enough power to USB devices >> Possible Solution?
    By Tuckie in forum General Hardware Discussion
    Last Post: 11-16-2005, 12:24 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. FS: USB TV / FM Tuner, haupauge usbtv
    By e36mp3 in forum Classified Archive
    Last Post: 11-18-2004, 11:03 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 02:56 PM
