Page 23 of 42 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 418
Thread: USB FM RDS Solution with sofware
  1. #221
    Sep 2006
    Im using the ADS Tech Stick with Silabs Chip.. it works with Silabs software but i cant get it working with radiator. I downloaded the Silabstestpack in the plugins folder and have chossed the subradio.dll in radiator setting as external dll. But nothing happens? any ideas?
  2. #222
    Low Bitrate jjnit's Avatar
    Feb 2007
    Quote Originally Posted by dudeness View Post
    Are you using the Radiator gui to test or RR?
    Check what the Radiator output is mapped to in its config.
    Sometimes it takes a channel change and then back for mine to produce audio after a boot - even static.
    That's all I can think of that I've experienced - I'm sure others have more ideas.
  3. #223
    Sep 2006
    Quote Originally Posted by jjnit View Post
    Im using the Radiator GUI atm. Where i can change the radiator output? I only can see the volume control. I restarted my pc serveral times and changed the channels with no result.
  4. #224
    Dec 2005
    Sydney
    have a look in the C file, it may be looking for a specific hardware name or part number before opening...
  5. #225
    Constant Bitrate almera's Avatar
    Aug 2004
    AFAIK you should select Volume Control (Internal) option. And have you tried USBRadio.dll?
  6. #226
    Sep 2006
    Quote Originally Posted by SmoL View Post
    Hm i cant find anything. The C file is really big and my c skills are not so good.
    @Almera: Yes, i tried the USBRadio.dll but nothing happenes when I use that .dll
  7. #227
    Mar 2007
    So what was the conclusion on the impedance problems by using a carantenna on this device?
    I want to change the carantenna to a windowantenna - Or should i go for a different/better approach if i'm going to use this device?
    If I order it from UK to Denmark it rates £35 incl shipping Didn't anyone get a load of the $5 ones?
    Does it come with some standard connector or are the included antenna hardwired?
  8. #228
    Newbie DeLorean Dave's Avatar
    Jul 2005
    Long Island, NY
    Have you guys tried the High Quality Computer Tuner, and if so, how does it compare to the tuner being talked about in this thread?
    1981 DeLorean DMC-12
    VIA SP13000, Xenarc 700TSV, 100GB hdd, 1GB ram, WinXP, BU335 GPS, iNav 3.0, Griffin PowerMate, M2-ATX, HQCT-AM/FM USB Radio (Software by Luc)
    PMD-1208 USB Data Acquisition
    Flux Capacitor
    Kensington USB 2.0 BT Dongle just dangling
  9. #229
    Mar 2007
    Quote Originally Posted by DeLorean Dave View Post
    Read a few pages back...
  10. #230
    Low Bitrate AyrtonSennaD's Avatar
    Feb 2006
    Montreal, Canada
    anyone know where i can found one i try all the link from this thread and they do not work also check the web and didn't find any.
    thanks
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Not enough power to USB devices >> Possible Solution?
    By Tuckie in forum General Hardware Discussion
    Last Post: 11-16-2005, 12:24 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. FS: USB TV / FM Tuner, haupauge usbtv
    By e36mp3 in forum Classified Archive
    Last Post: 11-18-2004, 11:03 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 02:56 PM
