I never tested inside. But it works ok when setting still, just not very well when moving.
Muldrick, was it ok when you tested in inside and got worse in the car? or is it the same as before?
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
What kind of car do you have? (ok, I see you have a Hyundai) I've read more about the stock antennas in some of the non-US cars and have seen the results myself. My brother's Infinity doesn't work well at all with the Silabs because of his stock "diversity" antenna. We're going to try getting a regular antenna to see if that helps.
The thing works GREAT in my F150.
Grayvader. You are saying that the same unit works good in your F150?
I'm asking because maybe you did a better soldering job on the truck unit, compared to the Infinity unit?????
I know I soldering mine correctly, otherwise I wouldn't have a signal at all, and it is better then just the plain wire that came with it, just not good enough.
"diversity" antenna. Would 2 antennas on my car act as a "diversity".
I tried a different length antenna (about 1-2 inches longer)...no better.
On that "diversity" note, if I run 2 antennas, should I have them at different lengths?
What about FM signal boosters (I "heard" they are useless) or signal "amplifiers" (not cheap).
Actually I tried both units in my truck and they both worked equally well so I know the solder job was ok on his.
And, yes, if you have 2 antennas, then you probably have a diversity antenna setup and your stock head unit has a tuner that knows what to do with two antennas. That's all I really know -- I don't know how to make it work. Hence, my brother trying a cheapo regular antenna. I'll you guys know how that works out.
I'm only regurgitating what I found doing a google search on reception problems with infinity/nissan cars. Apparently, aftermarket radios don't like the diversity setup either.
(I suspect the impedence mismatch of the "diverity" setup is part of the problem, but don't really know for sure)
Thanks.
No, I don't (currently) have 2 antennas, I was just wondering if that would help. (If I added another stock antenna on the right rear)
Yes...please let me (us) know how that regular antenna works for you.
My unit just came in and I have started testing. What amazing reception and audio quality!
I would agree with people that this is the best usb fm tuner so far. I can move the string antenna around without any flutter. It does help I can see the CN Tower from my house. 8*)
Just plug the usb radio into the usb port and fired up the software and it worked just fine under Vista.
RDS even works great...... Now off to Canadian Tire to soldier an antenna cable for the car...
I'm surprised that people have not mentioned the little LED that glows red then green. I though it was a nice indicator to see if the radio is player or not.
It's has better reception than my wintv usb device that is sitting beside it.
Dwaine
2003 Black Impala
DigitalFX4.0 Skin by JohnWPB
Road Runner RR's Myspace
My Ride - Car Domain Page -JWLionKing's MySpace Page
Project 98% Complete -FREE DOMAIN & WEBSPACE / FILE HOST FOR DEVELOPERS - PM ME
Anyone use an antenna adaptor that takes a +12V input yet?
The antenna adaptor I need to use has it. I've already tried using just a standard adaptor modified and soldered to the USB board, but the reception still sucked.
According the car forum I hang out at also, the amplified antenna adaptor is what I would use in an aftermarket HU install.
I'm a little concerned how the additional +12V load would affect the board seeing that I would be soldering the ground for the antenna onto it.
Anyone have any thoughts?
