About 95% done now. I don't know what i'm doing differently but mine works fine while driving. I get little minor pops and fades in and out now and then but its more than good enough until the HD tuner comes out.
So you've soldered the antenna connection jack onto the silabs, plugged that into your standard antenna in the car and have left the fuse in/removed the fuse? for the antenna and your getting a good signal?
I installed my carpc into my pet Kangaroo, mate.
Yup, i soldered a shielded cable to the silabs exactly like Bj did. I used a good mono audio cable instead of mini coax because i couldnt find any.
Then i ran that short cable (3-4 inches total probably) to this exact connector:
http://www.radioshack.com/product/in...entPage=search
From there it connects right to the subaru stock antenna connector.
You also NEED to make sure that your antenna is getting powered. It needs 12v. Look here: http://www.geocities.com/svxdc/WRX-pinout.htm
Pin 14 is what you're looking for, the blue one.
I did NOT use the extra capacitor, because as rando pointed out, there's already one built into the usb unit.
Yes i left the fuses untouched.
After that, i dunno man. Maybe try checking your usb connections etc. I'm also a very good solderer, its pretty hard to get a perfect solder job on that little board.
The powered antenna may be my problem.
When I tied into the harness to connect my speakers from my carpc, I left the power antenna wire disconnected which would mean that the power antenna isn't getting the juice it needs...
I'll have to take a look this evening after work!
man am i glad that i have the same car as lithoss!
