Page 35 of 42 FirstFirst ... 252627282930313233343536373839404142 LastLast
Results 341 to 350 of 418
Thread: USB FM RDS Solution with sofware
  1. #341
    Newbie scaff's Avatar
    Feb 2007
    Does anyone know of a uk supplier for this ?
    May 2007
    Wichita, KS
    mouser.com will ship to UK, thats where i got mine from
  3. #343
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Lithoss,
    How have you powered your antenna? Just connected it to the acc wire? I guess if the antenna did draw to much, the acc fuse would blow anyway and prevent any damage somewhere.
    I installed my carpc into my pet Kangaroo, mate.
  4. #344
    May 2007
    Wichita, KS
    Quote Originally Posted by NiSlo View Post
    Lithoss,
    I ran a 12v rail up to my lilliput from the psu in my computer, i tied it into that. acc would work, but yeah you might blow your fuse, i have no idea how much power the antenna pulls. i have my radar detector powered off acc, i've had no problems. eventually i think you'd want to give it something other than acc.
  5. #345
    Jul 2007
    Dundas
    I am a newbie, I installed roadrunner (and I think I have the version with silabs support but it didn't show silabs available in the drop down for config, I just edited the config file to set the value to 7), winamp, digitalfx skin, and have the silabs radio. I can get radio stations ok, but I don't get any RDS. I searched all of this thread and other places but I can't figure out if I am supposed to install something else or configure something to make RDS work.
    Regards
    David
  6. #346
    May 2007
    Wichita, KS
    Hmmm. i dont think i have any RDS data showing up either, come to think of it. I'm using centrafuse, but i think this may be a silabs problem. Anyone have any ideas?
  7. #347
    Dec 2005
    Sydney
    the acc should be ok, it goes off the car battery so wont be more than 9-13v at any given time. It could be less than 12v so you might want to put a mulimeter on it to check. My guess is that it would be ok
  8. #348
    May 2007
    Wichita, KS
    Quote Originally Posted by SmoL View Post
    Its not really voltage thats the problem, its how much current the components you put on the acc line pull. I think it might only be a 5A fuse, so you can't put too many things on it.
  9. #349
    Dec 2005
    Sydney
    wouldn't the atenna amplifier already be running of the acc line anyway.... If it was connected to a radio, and the radio runs on acc, then wouldnt taht mean the amplifier also runs on acc?
  10. #350
    May 2007
    Wichita, KS
    no, the radio has its own fused 12v supply. all the acc line does is signal that the ignition is on.
    http://www.geocities.com/svxdc/WRX-pinout.htm
    notice the seperate 12v input (pin6/yellow) and acc (pin10/red). i may be wrong, you should look at the fusebox to see which fuse is larger.
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Not enough power to USB devices >> Possible Solution?
    By Tuckie in forum General Hardware Discussion
    Last Post: 11-16-2005, 12:24 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. FS: USB TV / FM Tuner, haupauge usbtv
    By e36mp3 in forum Classified Archive
    Last Post: 11-18-2004, 11:03 AM
  5. USB FM solution good or crap?
    By Jake in forum General Hardware Discussion
    Last Post: 10-03-2002, 02:56 PM
